Like I say in my first post and in the title : I search the best way to powered a ESP32 with the minimal size.
with 18650, LiPo or button cell battery.
But thanks for your answers.
Powered ESP32 with 18650, LiPo, or button battery
Re: Powered ESP32 with 18650, LiPo, or button battery
bumped into this today and thought of you. would this work for you? it has enough output current for the ESP32.
https://www.dfrobot.com/product-1712.ht ... 2-19723189
I use one of these for portable esp32 power which works fine
https://www.ebay.com/itm/Raspberry-Pi-W ... e-no-cable
Thanks for the link. This regulator looks nice. I keep the link !!mikemoy wrote:bumped into this today and thought of you. would this work for you? it has enough output current for the ESP32.
Yes I have order this one on bangood, i wait the arrivalPibbotley wrote:I use one of these for portable esp32 power which works fine
in the meantime, i discover (because i've not fully read the doc) that the VIN pin on the dev board accept (6-20v)
https://docs.zerynth.com/latest/officia ... index.html
because the current flows in the board voltage regulator ...
My new question (i create a new topic for that) how to remove power led for opitimize consumption.
Thanks guys !!
I've occasionaly (accidently) supplied 12v to my dev kits but you can smell the LDO overheating in a matter of seconds. You would have to add heatsinks / forced cooling. To disable the power led flick it or its resistor off with a sharp tool, or cut the trace.
Ok,
I have physically remove the led with a solder iron and it works fine.
I've also try to powered my esp32 dev kit (DOIT) with first a 3,7v battery (18650 - 3,7v - 4A) without removed the power led and the battery died after 4-5 days
I try with a 9v battery (the board was heating) after removed the power led and the battery died after 2 days.
I try this two solutions with the same scenario : ESPEasy Firmware with a DS18B20, and 1hour deep sleep, with 15sec awake between each deep sleep.
Connection to a broker MQTT by WiFi and send temperature data during the 15sec awake.
I don't understand which consumes so much energy and how I can reduce this consumption.
- Change firmware (ESP-IDF maybe) ?
- Add a voltage regulator and powered the board with 5v or 3.3v instead of the VIN pin ?
- Use a board with integrated battery port ? (like lolin32 with LiPo or lolin32 with Li Ion battery (18650))
- Increase the deep sleep ?
- Reduce awake time ?
If you have any idea
Users browsing this forum: No registered users and 115 guests
