when i try to run debugger i get this error "libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED", any ideas?
$ bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp32-wrover.cfg
Open On-Chip Debugger 0.10.0-dev (2018-04-18-12:04)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: BreakIn BreakOut RunStallIn
Re: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
On what operating system are you running openocd?
Hi Alen,
It looks like maybe libusb is trying to poll some other USB device in your system. But then it moves on to the correct device, because the JTAG link comes up:
Angus
These lines indicate that not only is the USB connection working, the JTAG adapter is able to read data from the ESP32's debug port.Alen59 wrote: Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Angus
i am running windows 10kolban wrote:On what operating system are you running openocd?
Is this a driver problem? one youtube video say need to reintall all the driver.
If the connection otherwise works, it should be safe to ignore the ERROR lines.
Users browsing this forum: ESP_Sprite, Google [Bot] and 122 guests
