Hello all,
After updating ESP-IDF the "make flash" command stop working for me.
$ make flash
WARNING: esp-idf git submodule components/esp32/lib may be out of date. Run 'git submodule update' in IDF_PATH d ir to update.
WARNING: esp-idf git submodule components/mbedtls/mbedtls may be out of date. Run 'git submodule update' in IDF_ PATH dir to update.
WARNING: Missing submodule components/mbedtls/mbedtls...
Attempting 'git submodule update --init components/mbedtls/mbedtls' in esp-idf root directory...
Cloning into '/home/esp/esp-idf/components/mbedtls/mbedtls'...
0 [main] git-remote-https 18036 child_info_fork::abort: D:\Work\msys32\usr\bin\msys-icudata59.dll: Loaded to different address: parent(0x3110000) != child(0x2F60000)
error: cannot fork() for fetch-pack: Resource temporarily unavailable
fatal: clone of 'https://github.com/espressif/mbedtls.git' into submodule path '/home/esp/esp-idf/components/mbe dtls/mbedtls' failed
Failed to clone 'components/mbedtls/mbedtls'. Retry scheduled
1 [main] git-remote-https 23268 child_info_fork::abort: D:\Work\msys32\usr\bin\msys-icudata59.dll: Loaded to different address: parent(0x30A0000) != child(0x2F30000)
Failed to clone 'components/mbedtls/mbedtls' a second time, aborting
make: *** [D:/Work/msys32/home/esp/esp-idf/make/project.mk:530: /home/esp/esp-idf/components/mbedtls/mbedtls/.gi t] Error 1
Any suggestions ?
Thanks in advance
mingw32 stop working after ESP-IDF update
Re: mingw32 stop working after ESP-IDF update
I am extremely green on working on ESP32 in Windows but I had a similar problem. As I hunted google, I found a recipe that resolved my instance.
1. Go to where msys32 is installed. On my system it was C:\msys32.
2. Run "autorebase" script/batch file found there.
3. Reboot your Windows PC.
At this point, all worked for me.
Hello Kolban and thanks for you helpful answer.
Now it works for me
but still writing $ make flash monitor
WARNING: esp-idf git submodule components/esp32/lib may be out of date. Run 'git submodule update' in IDF_PATH dir to update.
It's OK for me at this point
Now it works for me
Users browsing this forum: Google [Bot] and 119 guests
