As a small contribution I have created an Open-source ESP-WROOM-32 breakout in Eagle.
The board contains reverse-voltage protection, 2 buttons (1 for reset and 1 for activating programming mode), and a diode on the RX line so the IC is 5V serial port compatible. It has breadboard compatible IO's and a 6-pin programmer header compatible with this FTDI Serial USB Cable: https://www.adafruit.com/products/70.
It is available at: https://github.com/StudioSophisti/ESP-W ... e-Breakout.
Any suggestions for improvements are welcome!
Users browsing this forum: Bing [Bot], greycon and 95 guests
