Is there a way to set MCPWM timers to reset on only rising edge/falling edge/LOW/HIGH incoming signal. I couldn't find a way on the esp read the docs as well as on manual.
Currently my timer get reset on both rising and falling edge of the incoming signal. I want to reset it only when the signal is LOW or it is either of rising or falling edge.
[img] [/img]
Sync pin problems on the MCPWM module
Re: Sync pin problems on the MCPWM module
Hi, amehta
I left some questions in " https://github.com/espressif/esp-idf/issues/2943 ", you can leave your comments in Github because I will get a email if there is any reply from you.
thanks !!
thanks !!
wookooho
Users browsing this forum: No registered users and 121 guests
