Hardware Pin Assignment
PaulVdBergh
Postby PaulVdBergh » Sat Jun 16, 2018 12:28 pm
Hi All,
My current project uses 13 I/O pins :
  • 5 Digital Outputs
    • 2 x RMT
      3 x GPIO
    4 Digital Inputs
    • 2 x RMT
      2 x GPIO
    4 Analog Inputs
I need to assign them to pins on the ESP32 modules. I consult table 19 in the TRM (IO MUX Pad Summary).
AFAIK, GPIO 0, 1, 3, 12, 13, 14, 15, 16 & 17 are in use (for reset, monitor, JTag and PSRam). Other pad names suggest they are in use for other functions (for example 32K_*, VDET_*, SENSOR_*).
Which pins are available for use without interfering with build-in features?
Thanks in advance,
Paul
mikemoy
Re: Hardware Pin Assignment
Postby mikemoy » Sun Jun 17, 2018 7:15 am
Are you using the Wrover or the Wroom ?
Do you plan on using JTAG ?
I dont use JTAG, and am using 12,13,14,15 for SPI. 4&5 for I2C, & GPIO2 for controlling a relay with no issues.
PaulVdBergh
Postby PaulVdBergh » Sun Jun 17, 2018 10:30 am
I'm planning my PCB layout for both, and initialy use the WROOM, but if specs requires WROVER, it will be no problem to use that module.
I foresee connectors to connect an ESP_PROG device to flash/monitor/debug the device, hence reserved the IOs required.
ATM, I'm evaluating if this config is usable :
Greets,
Paul.
Users browsing this forum: Google [Bot], nikita and 15 guests
