TCP server: assertion "netconn_alloc: undefined netconn_type" failed
Posted: Thu Jun 21, 2018 1:22 pm
by newsettler_AI
I'm using ESP32 as wifi AP with tcp server on it. Android phone runs app that have next logic:
1) connects to esp32 wifi AP
2) connects to TCP socket
3) exchanging TCP data (about 900 bytes (6 packets of 150 bytes) in total)
4) closing socket connection.
5) back to step 2.
Sometimes I got next error:
assertion "netconn_alloc: undefined netconn_type" failed: file "D:/Projects/ESP32/TOOLS/esp-idf/components/lwip/api/api_msg.c", line 696, function: netconn_alloc
abort() was called at PC 0x400d5383 on core 1
I have stydied behaviour of connection and have find out, that this happens after socket closed connection.
Some extended part of log:
[0;33mW (127916) TCP: connect socket error 128 Socket is not connected[0m
[0;33mW (127916) TCP: tcp disconnected... stop.
[0m
Code:128
[0;33mW (127916) TCP: (Socket is not connected)
[0m
socket closed
Backtrace: 0x4008ff38:0x3ffe3a60 0x4009010f:0x3ffe3a80 0x400d5383:0x3ffe3aa0 0x4017b59f:0x3ffe3ad0 0x4017b6ef:0x3ffe3af0 0x4018147d:0x3ffe3b10 0x40181e65:0x3ffe3b30 0x401848d6:0x3ffe3b50 0x4018aa6a:0x3ffe3b70 0x4017c0fd:0x3ffe3b90
Here is code of TCP server:
#define BUF_SIZE (512)
#define EXAMPLE_DEFAULT_PKTSIZE 1460
#define TCP_SERVER_IP   "192.168.4.1"
#define TCP_SERVER_PORT  333
typedef struct MyData_s
    uint8_t  TCP_Buf[BUF_SIZE];  // 512
    uint8_t  UART_Buf[BUF_SIZE];  //512
    uint32_t UART_RxCounter;
    uint32_t TCP_len;
    uint32_t UART_len;
    uint8_t  TCP_got_packet;
    uint8_t  UART_got_packet;
    bool     TCP_conn; // TRUE: tcp connected
}MyData_t;
void wifi_init_softap()
    wifi_event_group = xEventGroupCreate();
    tcpip_adapter_init();
    ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
    wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init(&cfg));
    wifi_config_t wifi_config = {
        .ap = {
            .ssid = WIFI_SSID,
            .ssid_len = strlen(WIFI_SSID),
            .max_connection = 1,
            .authmode = WIFI_AUTH_OPEN
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_LOGI(WIFI_TAG, "wifi_init_softap finished.SSID:%s password:%s",
             WIFI_SSID, WIFI_PASS);
esp_err_t create_tcp_server()
    ESP_LOGI(TCP_TAG, "server socket....port=%d\n", TCP_SERVER_PORT);
    server_socket = socket(AF_INET, SOCK_STREAM, 0);
    if (server_socket < 0) {
    	show_socket_error_reason(server_socket);
    	return ESP_FAIL;
    server_addr.sin_family = AF_INET;
    server_addr.sin_port = htons(TCP_SERVER_PORT);
    server_addr.sin_addr.s_addr = htonl(INADDR_ANY);
    if (bind(server_socket, (struct sockaddr*)&server_addr, sizeof(server_addr)) < 0) {
    	close(server_socket);
    	return ESP_FAIL;
    if (listen(server_socket, 5) < 0) {
    	return ESP_FAIL;
    connect_socket = accept(server_socket, (struct sockaddr*)&client_addr, &socklen);
    if (connect_socket<0) {
    	show_socket_error_reason(connect_socket);
    	return ESP_FAIL;
    /*connection established now can send/recv*/
    MyData.TCP_conn = true;
    ESP_LOGI(TCP_TAG, "tcp connection established!");
    ESP_LOGI(TCP_TAG, "socket:%d", server_socket);
    return ESP_OK;
bool tcp_server_task_restart; // TRUE: restart task
static void tcp_server_task(void *pvParameters)
    ESP_LOGI(TCP_TAG, "task tcp_conn.");
    tcp_server_task_restart = false;
    /*create tcp socket*/
    int socket_ret;
    ESP_LOGI(TCP_TAG, "tcp_server will start after 100ms!");
    vTaskDelay(100 / portTICK_RATE_MS);
    ESP_LOGI(TCP_TAG, "creating tcp server...");
    socket_ret=create_tcp_server();
    if(socket_ret == ESP_FAIL) {
		ESP_LOGI(TCP_TAG, "create tcp socket error,stop.");
		MyData.TCP_conn = false;
	    tcp_server_task_restart = true;
		vTaskDelete(NULL);
    while (!tcp_server_task_restart)
    	uint8_t databuff[EXAMPLE_DEFAULT_PKTSIZE]; // 1460
		int len = recv(connect_socket, databuff, EXAMPLE_DEFAULT_PKTSIZE, 0);
		MyData.TCP_len = len;
		if (len > 0)
			memcpy(MyData.TCP_Buf, databuff, MyData.TCP_len);
			printf("FL_len:%d, FL_data:%s\n", MyData.TCP_len, MyData.TCP_Buf); // debug
			MyData.TCP_got_packet = true;
    	vTaskDelay(10 / portTICK_RATE_MS);//every 10ms
		if (len <= 0)
			int err_ret = check_working_socket();
			if (err_ret == ECONNRESET || ECONNABORTED)
				ESP_LOGW(TCP_TAG, "tcp disconnected... stop.\n");
				printf("Code:%d\n", err_ret);
				if(err_ret == ENOTCONN)
				    ESP_LOGW(TCP_TAG, "(Socket is not connected)\n");
				break;
    close_socket();
    printf("socket closed\n");
    vTaskDelete(NULL);
static void watch_tcp_srv_task(void *pvParameters)
  while(1)
	  if(tcp_server_task_restart == true)
		  printf("TCP task is RESTARTING\n\n");
	      xTaskCreate(&tcp_server2_task,"tcp_server_task", 4096, NULL, 5, NULL);
	      printf("tcp_server2_task created\n");
	  vTaskDelay(1000 / portTICK_RATE_MS);//every 1s
void app_main()
    //WIFI
    ESP_LOGI(WIFI_TAG, "ESP_WIFI_MODE_AP");
    wifi_init_softap();
    //TCP
    xTaskCreate(&tcp_server_task, "tcp_server_task", 4096, NULL, 5, NULL);
    xTaskCreate(&watch_tcp_srv_task, "watch_tcp_srv_task", 1024, NULL, 5, NULL);
First task starts TCP server and processing TCP connection on socket.
Here is part of log to see route:
tcp_server_task created
[0;32mI (118796) TCP: task tcp_conn.[0m
[0;32mI (118796) TCP: tcp_server will start after 100ms![0m
[0;32mI (118896) TCP: creating tcp server...[0m
[0;32mI (118896) TCP: server socket....port=333
[0m
[0;32mI (119476) TCP: tcp connection established![0m
[0;32mI (119476) TCP: socket:4104[0m
[0;32mI (120106) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$i}t
FL_len:11, FL_data:$VЊt
[0;32mI (120576) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$VЊt„Іа
FL_len:11, FL_data:$iЃt
[0;32mI (121046) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$iЃt
FL_len:11, FL_data:$`Њ©t
[0;32mI (121516) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$`Њ©t
FL_len:11, FL_data:$`Њ®t
[0;32mI (121986) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$`Њ®t
FL_len:11, FL_data:$VЊ·t
[0;32mI (122456) GOT FULL PACKET:, size: 150[0m
FL_UART(len:150):$VЊ·t
[0;33mW (123086) TCP: connect socket error 128 Socket is not connected[0m
[0;33mW (123086) TCP: tcp disconnected... stop.
[0m
Code:128
[0;33mW (123086) TCP: (Socket is not connected)
[0m
socket closed
Second task is monitoring state of tcp server - if socket has been closed, tcp_server_task deletes and "watchdog" task re-creating it.
Not sure if this is good way, but it worked until android app (new version) started to re-opening sockets each 900 bytes.
Re: TCP server: assertion "netconn_alloc: undefined netconn_type" failed
Posted: Thu Jun 21, 2018 2:12 pm
by kolban
I think it would be useful to know which source statement in the user application is being called which generates the failure. Hopefully it is the same statement each time.
Posted: Fri Jun 22, 2018 11:27 am
by newsettler_AI
kolban wrote:I think it would be useful to know which source statement in the user application is being called which generates the failure. Hopefully it is the same statement each time.
It comes after closing socket:
void close_socket()
close(connect_socket);
I cant say what exactly is going on at android app... :(
