make menuconfig change log level, But looks like the CONFIG_LOG_DEFAULT_LEVEL_INFO macro not using in C source code, why
wziy520
Postby wziy520 » Fri Dec 02, 2016 9:27 am
make menuconfig change log level, But looks like the CONFIG_LOG_DEFAULT_LEVEL_INFO macro not using in C source code, why?how to make the Macro define works?
kolban
Re: make menuconfig change log level, But looks like the CONFIG_LOG_DEFAULT_LEVEL_INFO macro not using in C source code,
Postby kolban » Fri Dec 02, 2016 4:27 pm
Are you including the header called "sdkconfig.h" in your source files?
ESP_igrr
Postby ESP_igrr » Fri Dec 02, 2016 4:54 pm
What debug level have you set in menuconfig?
CONFIG_LOG_DEFAULT_LEVEL_INFO macro will only be defined if the debug level is set to "Info".
wziy520
Postby wziy520 » Mon Dec 05, 2016 7:58 am
yes, include "sdkconfig.h" file.
but I can't find "CONFIG_LOG_DEFAULT_LEVEL_INFO" in other part of source code. how i can get where it works.
Users browsing this forum: Bing [Bot] and 14 guests
