:~/esp/openocd-esp32$ bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev (2018-06-04-09:50)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
force hard breakpoints
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
JTAG Debug Problem
Re: JTAG Debug Problem
What OS are you using? What hardware are you using? Does the serial port on the hardware work?
Users browsing this forum: No registered users and 110 guests
