Hello All,
Can anyone tell me what is the differences between DevKitC and PICO-KIT ?
Thank you in advance,
ESP32 DevKitC vs ESP32-PICO-KIT
Re: ESP32 DevKitC vs ESP32-PICO-KIT
Pico dev board is a "chip level" reference design, where as the devkit is a "module" based reference design.
They both perform the same, but are different reference circuits for different use cases. For example, if you you will eventually make your own device (where size is a constraint), you may opt to develop and test your circuitry on a Pico kit. If you don't care about size, and want a FCC certified module, then go with the devkit.
Also, since Pico does not yet support external PSRAM (only the wrover based designs support that ATM).
The Pico doesn't have the CAN bus features (well mine doesn't!).
Users browsing this forum: cdollar and 224 guests
