Field initialization of product
Re: Field initialization of product
Hi Tom - the powers that be have dictated that I include a serial interface, so there's no getting away from it now. I'll return my attention to more elegant alternatives after I get this working.
Here is my working code to connect a second hardware serial port; I had problems with the other uart/gpio combinations. Maybe this will save you a few minutes.
#include <HardwareSerial.h>
HardwareSerial hardwareSerial2(2);
delay(1000);
hardwareSerial2.begin(115200, SERIAL_8N1, 16, 17); GPIO 16,17
hardwareSerial2.write("aaa\n");
delay(1000);
while (hardwareSerial2.available() > 0) {
Serial.print( (char) hardwareSerial2.read());
Tom Meyers
delay(1000);
delay(1000);
Tom Meyers
IT Professional, Maker
Santiago, Dominican Republic
Thanks, Tom. My board is using UART1 with the default pins...I'm trying to send it about 80 bytes of data, but it can't handle it all. I get a "uart rx break" (whatever that is) after about 65 bytes read, and subsequent reads produce garbage.
It's as though either the FTDI chip or the ESP32 UART is getting overrun, but I just find that hard to believe. Not sure where to go from here...
EDIT: sometimes I get uart frame errors as well. Weird stuff.
EDIT #2: above I wrote that "subsequent reads produce garbage;" this isn't strictly true. The contents of the subsequent reads are all null characters.
So, here's the sequence of events:
1. I get part of my incoming message (about 65 bytes worth)
2. I get a uart rx break
3. I get several more read events, of varying lengths, with data all null.
4. Each of these subsquent reads then gets a uart rx break.
Users browsing this forum: No registered users and 141 guests
