I'm trying to figure out how to listen on more than one port at a time with the AT command TCP server. Or if that is not possible, how can I have more than one server running at a time (although I'm pretty sure that can't be done).
I can start a server "AT+CIPSERVER=1,444" for example and multiple clients can connect OK on port 444. If I want to "add" another port to listen on, it does not work using simply "AT+CIPSERVER=1,555" for example. Unless I close down the currently running server (ie. AT+CIPSERVER=0) and start again with ""AT+CIPSERVER=1,555".
Is there a way of doing this with the off-the shelf AT environment? Any thoughts would be appreciated. Thanx in advance!
ESP32 AT command TCP server with multiple ports
Users browsing this forum: No registered users and 113 guests
