UART FIFO issue after updating ESP-IDF
jollytopper
Postby jollytopper » Wed Sep 19, 2018 10:30 am
CLOSED
jollytopper
CLOSED Re: UART FIFO issue after updating ESP-IDF
Postby jollytopper » Thu Sep 20, 2018 4:29 am
Solved
ESP_Sprite
Postby ESP_Sprite » Thu Sep 20, 2018 8:34 am
Can you also say what the issue was and what the solution was? It's a bit frustrating if someone from the future has a similar issue and just reads 'CLOSED" here instead of what you ran into.
jollytopper
Postby jollytopper » Fri Oct 12, 2018 5:48 am
Sorry about that! I really wanted to delete the post because I felt it was a silly issue.
Issue: UART FIFO getting random pieces of data leftover.
Reason: I was using IO pins that JTAG uses.
ESP_Sprite
Postby ESP_Sprite » Sat Oct 13, 2018 3:44 am
No problem, thanks for updating us :)
Users browsing this forum: Bing [Bot], ESP_igrr and 30 guests
