WDT reset due to flash access lock-up
0xffff
Postby 0xffff » Sun Oct 07, 2018 8:07 pm
I'm running ESP32 w/ 2 CPUs. Occasionally, I get a WDT resest:
W (85) boot: PRO CPU has been reset by WDT.
W (85) boot: WDT reset info: PRO CPU PC=0x40084d50
W (86) boot: WDT reset info: APP CPU PC=0x40088214
Looking at the two addresses in gdb:
(gdb) list *0x40084d50
0x40084d50 is in spi_flash_op_block_func (/proj/Firmware/esp-idf/components/spi_flash/./cache_utils.c:82).
77	    // s_flash_op_complete flag is cleared on *this* CPU, otherwise the other
78	    // CPU may reset the flag back to false before IPC task has a chance to check it
79	    // (if it is preempted by an ISR taking non-trivial amount of time)
80	    s_flash_op_complete = false;
81	    s_flash_op_can_start = true;
82	    while (!s_flash_op_complete) {
83	        // busy loop here and wait for the other CPU to finish flash operation
84	    }
85	    // Flash operation is complete, re-enable cache
86	    spi_flash_restore_cache(cpuid, s_flash_op_cache_state[cpuid]);
(gdb) list *0x40088214
0x40088214 is in vTaskExitCritical (/proj/Firmware/esp-idf/components/freertos/./tasks.c:4278).
4273	#ifdef CONFIG_FREERTOS_PORTMUX_DEBUG
4274			vPortCPUReleaseMutexIntsDisabled( mux, function, line );
4275	#else
4276			vPortCPUReleaseMutexIntsDisabled( mux );
4277	#endif
4278			if( xSchedulerRunning != pdFALSE )
4279			{
4280				TCB_t *tcb = pxCurrentTCB[xPortGetCoreID()];
4281				BaseType_t nesting = tcb->uxCriticalNesting;
4282				if( nesting	 > 0U )
So it seems that the PRO CPU hangs waiting for the APP CPU to give up the access to the flash, but seems the task scheduler state is stuck at taskSCHEDULER_NOT_STARTED? I have at least a half-dozen tasks running - is it one of my tasks that is causing issues? Any ideas on debugging this?
0xffff
Re: WDT reset due to flash access lock-up
Postby 0xffff » Mon Oct 15, 2018 5:04 pm
Someone from ESP? Help? :)
ESP_Sprite
Postby ESP_Sprite » Tue Oct 16, 2018 2:45 am
Hard to say, and your symptoms don't really ring a bell - are you sure this isn't caused by e.g. memory corruption? Any chance you can whittle your code down to the smallest example that gives you this behaviour?
Users browsing this forum: mubeenkhalid007 and 241 guests
