By ordering the output pwm and / or the high of the H-bridge which commands the motor dc I saw a long time ago how to produce some sounds.
But I forget that.
I want to identify with the start of the micro controller that everything is ok after the motor will be normaly commanded
A piece of code with IDE arduino would be appreciated or an URL
make few sound with a motor dc
Re: make few sound with a motor dc
froussel wrote:
A piece of code ...
did not played with this on esp32..
and not from me, but think should be can transformed to the esp32 that work's
hope this helps you:
void playSound(uint16_t freq, uint16_t duration_msec, uint8_t amplitude) {
uint32_t n,k,period_usec,duration_usec;
period_usec = 1000000L / freq;
duration_usec = 1000 * (uint32_t) duration_msec;
k = duration_usec / period_usec;
motorSpeed (amplitude, amplitude);
for (n = 0; n < k; n++) {
motorDirection (DIR_FORWARD, DIR_FORWARD);
delayMicroseconds(period_usec/2);
motorDirection (DIR_REVERSE, DIR_REVERSE);
motorSpeed (0, 0);
rudi
sure .. here you go...or an ULR ...
and .. here
Re: make few sound with a motor dc (solved)
Thanks!
Just must do it now
Just must do it now
I tried
No sound
please why ?
- void motorAv()
- { digitalWrite(inaPin, HIGH);
- digitalWrite(inbPin, LOW); }
- void motorAr()
- { digitalWrite(inaPin, LOW);
- digitalWrite(inbPin, HIGH); }
- void motorStop()
- void playSound(uint16_t freq, uint16_t duration_msec, uint8_t amplitude)
- { uint32_t n,k,period_usec,duration_usec;
- period_usec = 1000000L / freq;
- duration_usec = 1000 * (uint32_t) duration_msec;
- k = duration_usec / period_usec;
- pwm= amplitude; // pwm max driver motor = 100%
- for (n = 0; n < k; n++)
- { motorAv();
- delayMicroseconds(period_usec/2);
- motorAr();
- delayMicroseconds(period_usec/2); }
- motorStop; }
- uint16_t freq = 1000; // max 65535
- uint16_t duration_msec = 400;
- uint8_t amplitude=255;
- for (int i =15000; i < 19000; i = i +100)
- { delay(100);
- playSound(i, duration_msec, amplitude);
please why ?
I'm alone ?
did you test, you can drive the motor normal?
is the motor working? how much sink it?
which motor you use?
how you drive the motor by hardware?
or do you use (later) motor drivers ics? ( example uln2003 )
and how looks your hardware setup?
rudi
rudi
Yes
Brushed DC motoris the motor working? how much sink it?
Thing as https://www.pololu.com/product/708how you drive the motor by hardware?
When reading this
http://esp8266.github.io/Arduino/versio ... log-output
I wonder if I have an error in the maximum of 255 for the pwm
Should not I put 1023 instead?
Alsobest wishes
rudi
My stepper motor website:skysmotor.com - Machinery Design - Stepper Moter Development
"Necessity is the mother of invention." - Author unknown.
as you type.
as you type.
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot], Rckyan and 128 guests
