Python installation - Windows
APrince
Postby APrince » Mon Nov 19, 2018 10:00 am
I've been following the Getting Started guide successfully, till I came to the section where I am supposed to install Python packages. The thing is that there was no previous mention of installing the Python itself. What I don't understand is whether this is supposed to be the Python instance installed on the Windows host OS, or whether it refers to a Python instance installed within msys2 using some package manager (pacman?). Either way, I think that this section could use some improvements.
Anyway in my case,
python --version
says
-bash: python: command not found
So how should I install Python and which one preferably?
ESP_krzychb
Contact:
Re: Python installation - Windows
Postby ESP_krzychb » Mon Nov 19, 2018 12:47 pm
Hi APrince,
Have you run mingw32.exe as described in Check it Out?
Python is already included in this installation. No need to install it.
I see what you see if I run msys2.exe or mingw64.exe.
APrince
Postby APrince » Mon Nov 19, 2018 6:26 pm
My bad... You are right. I was launching msys instead of mingw.
ESP_Sprite
Postby ESP_Sprite » Mon Feb 04, 2019 12:57 pm
Locking this, as for some reason this question attracts spammers... feel free to start a new post if anyone has issues with specifically the ESP-IDF Python bits.
Users browsing this forum: Baidu [Spider] and 118 guests
