I wrote a lot of C++ classes using traditional C++. Now I'm studyng C++11, C++14 and so on. I would like to see if my efforts results in better machine code.
In AVR GCC one could generate an .lls file, a conbination of C++ statements with the corresponding assembler instructions.
Is this also possible with ESP32/ESP-IDF, and how can I do this?
Thanks,
Paul
How to obtain documented assembly listing ?
- PaulVdBergh
- ESP_krzychb
- Contact:
Re: How to obtain documented assembly listing ?
Hi PaulVdBergh,
FWIW when using ESP32 with JTAG you can see (and navigate through) both the C code and machine code side by side.
- PaulVdBergh
Hi krzychb,
That is one option... But my experience with JTAG debugging on ESP32 devices is disappointing... When more threads are running in the debugger things get very obfuscated..
I rather would like to have listings of the generated assembly to compare the different compilations.
However, thanks for your suggestion.
Paul
Paul
One option is to start xtensa-esp32-elf-gdb <elf file> and then execute "disassemble /m <function name>".
You don't need to connect to the target to do this.
Thanks - That was very help full for the DSP stuff I am working on.
I have been using obj dump until now but this is much more lean.
/Jakobsen
/Jakobsen
Analog Digital IC designer / DevOps @ Merus Audio, Copenhagen, Denmark.
We do novel and best in class Audio amplifiers for consumer products.
Programmed assembler for C-64 back in 1980's, learned some electronics - hacking since then
Users browsing this forum: No registered users and 93 guests
