Using spiffs and FreeRTOS tick hook causes crash
newsettler_AI
Postby newsettler_AI » Mon Dec 24, 2018 5:29 pm
Hi.
In my project I'm using SPIFFS and some FreeRTOS tasks. One of this tasks (its LCD library) uses callback for ticks:
https://github.com/espressif/esp-idf/bl ... ooks.h#L90
Problem: each tasks works fine separatly. But when I'm trying use both I got crash:
Guru Meditation Error: Core  0 panic'ed (Cache disabled but cached memory region
 accessed)
Core 0 register dump:
PC      : 0x400d632c  PS      : 0x00060034  A0      : 0x8008dcd5  A1      : 0x3f
fc05a0
0x400d632c: callback_tick_task at C:/Projects/ESP32/Projects/LCD_project/main/lvgl_tf
t.c:599
A2      : 0x00000001  A3      : 0x00000000  A4      : 0x00060920  A5      : 0x00
000001
A6      : 0x00060923  A7      : 0x00060023  A8      : 0x80081cc4  A9      : 0x3f
fc4728
A10     : 0x00000003  A11     : 0x00060923  A12     : 0x00060920  A13     : 0x00
000001
A14     : 0x00060920  A15     : 0x3ffbcac1  SAR     : 0x00000017  EXCCAUSE: 0x00
000007
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00
000000
Core 0 was running in ISR context:
EPC1    : 0x400838e9  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x40
0d632c
0x400838e9: spi_flash_op_block_func at C:/Projects/ESP32/TOOLS/esp-idf/component
s/spi_flash/cache_utils.c:82 (discriminator 1)
t.c:599
Backtrace: 0x400d632c:0x3ffc05a0 0x4008dcd2:0x3ffc05c0 0x4008e56f:0x3ffc05e0 0x4
008f0e5:0x3ffc0600 0x400825f2:0x3ffc0610 0x400838e6:0x00000000
t.c:599
0x4008dcd2: xTaskIncrementTick at C:/Projects/ESP32/TOOLS/esp-idf/components/fre
ertos/tasks.c:3564
0x4008e56f: xPortSysTickHandler at C:/Projects/ESP32/TOOLS/esp-idf/components/fr
eertos/port.c:374
0x4008f0e5: _frxt_timer_int at C:/Projects/ESP32/TOOLS/esp-idf/components/freert
os/portasm.S:303
0x400825f2: _xt_lowint1 at C:/Projects/ESP32/TOOLS/esp-idf/components/freertos/x
tensa_vectors.S:1105
0x400838e6: spi_flash_op_block_func at C:/Projects/ESP32/TOOLS/esp-idf/component
s/spi_flash/cache_utils.c:81
Rebooting...
FreeRTOS ticks callback
static void callback_tick_task(void)
    custom_tick_inc(portTICK_RATE_MS);
Task that uses this callback
void my_1_task(void* arg)
    esp_register_freertos_tick_hook(callback_tick_task);
    while(1)
       vTaskDelay(1);
       task_1_handler();
Task that reads text files from spiffs image
void my_2_task (void *arg)
    uint32_t cnt = 0;
    while(1)
        cnt++;
        if(cnt > 2) // each 2 seconds switch file
            load_file_from_spiffs(my_files[file_id]);
            file_id++;
            cnt = 0;
            //just a loop for loading files
            if(file_id >=  4)  file_id = 0;
        vTaskDelay(1000);
Also I have read this article:
https://docs.espressif.com/projects/esp ... n-accessed
Looks like reason of crash is because task_2 (reading file) disables others tasks until flash operations are in progress.
But I'm not sure where and how apply recommended attribute ESP_INTR_FLAG_IRAM (I suppose I have apply it to callback_tick_task function?).
ESP_igrr
Re: Using spiffs and FreeRTOS tick hook causes crash
Postby ESP_igrr » Tue Dec 25, 2018 1:19 am
This is correct, callback_tick_task, custom_tick_inc and other functions called from the tick hook need to be placed into IRAM using IRAM_ATTR attribute (declared in esp_attr.h).
newsettler_AI
Postby newsettler_AI » Tue Dec 25, 2018 12:47 pm
ESP_igrr, thanks a lot !
I tried apply IRAM_ATTR only for callback itself, but no success.
Now I added this attibutes to all functions in this callback aswell and it works fine :)
Users browsing this forum: Baidu [Spider], Bing [Bot] and 25 guests
