edit components
georgecarlo
edit components
Postby georgecarlo » Fri Jan 18, 2019 6:05 am
Hello People,
I am using the kolban's ble libraries for esp32 in my project. My problem is i want guidance on how to properly configure the component.mk for additional libraries and also i have a clash were my project code is in C and the ble example by neil is in C++, i just want to change my project from C to C++ so that all together everything runs from C++
my component .mk has to be configured to add libraries by kolban.
my project C code
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
int ledPin = 18; // choose the output pin for the LED
int ledPin2 = 23; // choose the output pin2 for the LED
int inPin = 21;   // choose the input pin (for a pushbutton)
int inPin2 = 4; // choose the input pin2 (for a pushbutton2)
int val = 0;  // variable for reading the pin status
int val2 = 0; // variable for reading the pin2 status
void pbm_task(void *pvParameter)
    gpio_pad_select_gpio(ledPin);
    gpio_set_direction(ledPin, GPIO_MODE_OUTPUT);
    gpio_pad_select_gpio(ledPin2);
    gpio_set_direction(ledPin2, GPIO_MODE_OUTPUT);
    gpio_pad_select_gpio(inPin);
    gpio_set_direction(inPin, GPIO_MODE_INPUT);
    gpio_pad_select_gpio(inPin2);
    gpio_set_direction(inPin2, GPIO_MODE_INPUT);
void pb1_task(void *pvParameter)
    val = gpio_get_level(inPin);
    while(1)
        if(val == 1)
           gpio_set_level(ledPin, 1);
           printf("BUTTON 1 ON!");
        else
           gpio_set_level(ledPin, 0);
           printf("BUTTON 1 OFF!");
void pb2_task(void *pvParameter)
    val2 = gpio_get_level(inPin2);
    while(1)
        if(val2 == 1)
            gpio_set_level(ledPin2, 1);
            printf("BUTTON 2 ON!");
        else
            gpio_set_level(ledPin2, 0);
            printf("BUTTON 2 OFF!");
void app_main()
    xTaskCreate(&pbm_task, "pbm_task", 2048, NULL, 5, NULL);
    xTaskCreate(&pb1_task, "pb1_task", 2048, NULL, 5, NULL);
    xTaskCreate(&pb2_task, "pb2_task", 2048, NULL, 5, NULL);
and im using neil's bleserver.cpp as an example and combine my code into C++
Users browsing this forum: Majestic-12 [Bot] and 221 guests
