Compression using miniz
jubueche
Postby jubueche » Fri Feb 08, 2019 10:26 am
I am trying to run the test sketch for miniz compression. However, my heap space is too small (available size is bigger, but fragmented) and I was wondering how to reduce the size used by
tdefl_compressor
without breaking the algorithm.
Here is the short code that I am trying to run:
#include "freertos/task.h"
#include "rom/miniz.h"
#include "unity.h" //testing
#include "stdlib.h"
#include "stdio.h"
#define DATASIZE (1024*1)
extern "C"{
#include "wifi_synch.h"
extern "C" void app_main()
	int x;
	char b;
	char *inbuf, *outbuf;
	tdefl_compressor *comp;
	tinfl_decompressor *decomp;
	tdefl_status status;
	size_t inbytes = 0, outbytes = 0, inpos = 0, outpos = 0, compsz;
	printf("Allocating compressor & outbuf (%d bytes)\n", sizeof(tdefl_compressor));
	comp = (tdefl_compressor *) malloc(sizeof(tdefl_compressor));
	TEST_ASSERT(comp != NULL);
	printf("Allocating data buffer and filling it with semi-random data\n");
	inbuf = (char *) malloc(DATASIZE*sizeof(char));
	TEST_ASSERT(inbuf != NULL);
	srand(0);
	for (x = 0; x < DATASIZE; x++) {
		inbuf[x] = (x & 1) ? rand() & 0xff : 0;
	int free_space = heap_caps_get_free_size(MALLOC_CAP_8BIT);
	printf("Free space is %d\n", free_space);
	outbuf = (char *) malloc(DATASIZE);
	TEST_ASSERT(outbuf != NULL);
	printf("Compressing...\n");
	status = tdefl_init(comp, NULL, NULL, TDEFL_WRITE_ZLIB_HEADER | 1500);
	TEST_ASSERT(status == TDEFL_STATUS_OKAY);
	while (inbytes != DATASIZE) {
		outbytes = DATASIZE - outpos;
		inbytes = DATASIZE - inpos;
		tdefl_compress(comp, &inbuf[inpos], &inbytes, &outbuf[outpos], &outbytes, TDEFL_FINISH);
		printf("...Compressed %d into %d bytes\n", inbytes, outbytes);
		inpos += inbytes; outpos += outbytes;
	compsz = outpos;
	free(comp);
	//Kill inbuffer
		inbuf[x] = 0;
	free(inbuf);
	inbuf = outbuf;
	printf("Reinflating...\n");
	decomp = (tinfl_decompressor *) malloc(sizeof(tinfl_decompressor));
	TEST_ASSERT(decomp != NULL);
	tinfl_init(decomp);
	inpos = 0; outpos = 0;
	while (inbytes != compsz) {
		inbytes = compsz - inpos;
		tinfl_decompress(decomp, (const mz_uint8 *)&inbuf[inpos], &inbytes, (uint8_t *)outbuf, (mz_uint8 *)&outbuf[outpos], &outbytes, TINFL_FLAG_PARSE_ZLIB_HEADER);
		printf("...Decompressed %d into %d bytes\n", inbytes, outbytes);
	printf("Checking if same...\n");
	srand(0);
		b = (x & 1) ? rand() & 0xff : 0;
		if (outbuf[x] != b) {
			printf("Pos %x: %hhx!=%hhx\n", x, outbuf[x], b);
			TEST_ASSERT(0);
	printf("Great Success!\n");
	free(inbuf);
	free(outbuf);
	free(decomp);
	while(1){
		vTaskDelay(100);
I am also looking into zlib.
I am trying to compress sensor readings. My plan is to continuously read sensor data into heap memory that is say 32kB and each time I hit say 16kB, I compress this chunk and write it to external SPI flash. OR I can write everything to external flash and compress ~16MB worth of data before uploading to the cloud. What do you think is better? I don't know how long it takes to compress 16MB worth of data.
Also what compression rate at normal compression level (6 for zlib) can be expected?
Return to “General Discussion”
Users browsing this forum: No registered users and 16 guests
