zlib on esp32
jubueche
zlib on esp32
Postby jubueche » Sun Feb 10, 2019 10:02 pm
I am currently working on gettingt zlib to work on the esp32. The compression already works, but there is some error when trying to close the compressed file. Anyway, here is the code for anybody who wants to use it. I will update it as soon as I will find the bug.
#include "freertos/task.h"
#include "stdlib.h"
#include "stdio.h"
#include <stdio.h>
#include <string.h>
#include <assert.h>
#include "zlib.h"
#include "esp_vfs_fat.h"
#include "diskio.h"
#include <dirent.h>
const char * base_path =  "/spiflash";
static wl_handle_t s_wl_handle = WL_INVALID_HANDLE;
const char * TAG = "FATFS";
void print_dr(void);
void zerr(int ret);
void remove_folder(void);
#define WINDOW_SIZE 9
#define MEM_LEVEL 1
#define GZIP_ENCODING 16
#define CHUNK 16384
FILE * foo;
FILE * comp;
FILE * recon;
int def(FILE *source, FILE *dest, int level)
    int ret, flush;
    unsigned have;
    z_stream strm;
	//Allocating on the stack only works for very small chunk sizes.
    /*unsigned char in[CHUNK];
    unsigned char out[CHUNK];*/
    unsigned char * in = (unsigned char *) malloc(CHUNK * sizeof(char));
    unsigned char * out = (unsigned char *) malloc(CHUNK * sizeof(char));
    strm.zalloc = Z_NULL;
    strm.zfree = Z_NULL;
    strm.opaque = Z_NULL;
    ret = deflateInit2(&strm, level,Z_DEFLATED, WINDOW_SIZE ,MEM_LEVEL,Z_DEFAULT_STRATEGY);
    if (ret != Z_OK){
    	return ret;
    do {
        strm.avail_in = fread(in, 1, CHUNK, source);
        if (ferror(source)) {
            zerr(deflateEnd(&strm));
            return Z_ERRNO;
        flush = feof(source) ? Z_FINISH : Z_NO_FLUSH;
        strm.next_in = in;
        do {
            strm.avail_out = CHUNK;
            strm.next_out = out;
            ret = deflate(&strm, flush);
            assert(ret != Z_STREAM_ERROR);
            zerr(ret);
            have = CHUNK - strm.avail_out;
            for(int i=0;i<have;i++)
            	printf("%c", out[i]);
            if (fwrite(out, sizeof(char), have, dest) != have || ferror(dest)) {
                return Z_ERRNO;
        } while (strm.avail_out == 0);
        assert(strm.avail_in == 0);
    } while (flush != Z_FINISH);
    assert(ret == Z_STREAM_END);
    free(in);
    free(out);
    return Z_OK;
int inf(FILE *source, FILE *dest)
	int ret;
	unsigned have;
	z_stream strm;
	strm.avail_in = 0;
	strm.next_in = Z_NULL;
	ret = inflateInit2(&strm,0); //Use window size in compressed stream
	if (ret != Z_OK)
		return ret;
	ESP_LOGI(TAG, "Inited Inflation");
	do {
		ESP_LOGI(TAG, "Could read");
			(void)inflateEnd(&strm);
			return Z_ERRNO;
		if (strm.avail_in == 0)
		strm.next_in = in;
		do {
			ret = inflate(&strm, Z_NO_FLUSH);
			switch (ret) {
			case Z_NEED_DICT:
				ret = Z_DATA_ERROR;
			case Z_DATA_ERROR:
			case Z_MEM_ERROR:
				return ret;
			if (fwrite(out, 1, have, dest) != have || ferror(dest)) {
				return Z_ERRNO;
	} while (ret != Z_STREAM_END);
	    free(in);
	    free(out);
		return ret == Z_STREAM_END ? Z_OK : Z_DATA_ERROR;
extern "C" void app_main()
	esp_vfs_fat_mount_config_t mount_config = {};
	mount_config.max_files = 4;
	mount_config.format_if_mount_failed = true;
	mount_config.allocation_unit_size = CONFIG_WL_SECTOR_SIZE;
	esp_err_t err = esp_vfs_fat_spiflash_mount(base_path, "storage", &mount_config, &s_wl_handle);
	if (err != ESP_OK) {
		ESP_LOGE(TAG, "Failed to mount FATFS (%s)", esp_err_to_name(err));
		return;
	print_dr();
	remove_folder();
	print_dr();
	ESP_LOGI(TAG, "Opening file");
	foo = fopen("/spiflash/foo.bin", "wb");
	if (foo == NULL) {
		ESP_LOGE(TAG, "Failed to open file for writing");
		return;
	int ret = fprintf(foo, "written using ESP-IDF %s\n", esp_get_idf_version());
	if(ret < 0){
		ESP_LOGE(TAG, "Error writing file");
	if(fclose(foo) == EOF){
		ESP_LOGE(TAG, "Error closing the file.");
	else ESP_LOGI(TAG, "File written");
	foo = fopen("/spiflash/foo.bin", "rb");
	if(foo == NULL){
		ESP_LOGE(TAG, "Error opening the file.");
	comp = fopen("/spiflash/comp.bin", "wb");
	if (comp == NULL) {
		return;
	print_dr();
	uint8_t level = 6;
	zerr(def(foo, comp, level));
	ESP_LOGI(TAG, "Compressed.");
		ESP_LOGE(TAG, "Error closing file");
	ESP_LOGI(TAG, "Closed foo.");
	if(fclose(comp) == EOF){
	ESP_LOGI(TAG, "Closed comp.");
	//Inflate
	recon = fopen("/spiflash/rec.bin", "wb");
	comp = fopen("/spiflash/comp.bin", "rb");
	if(recon == NULL || comp == NULL){
		ESP_LOGE(TAG, "Error opening file before inflating.");
	ESP_LOGI(TAG, "Start inflating");
	zerr(inf(comp, recon));
	ESP_LOGI(TAG, "Stopped inflating");
	ESP_LOGI(TAG, "Closed comp");
	if(fclose(recon) == EOF){
	ESP_LOGI(TAG, "Closed recon");
	// Open file for reading
	ESP_LOGI(TAG, "Reading file");
	recon = fopen("/spiflash/rec.bin", "rb");
	if (recon == NULL) {
		ESP_LOGE(TAG, "Failed to open file for reading");
		return;
	char line[128];
	fgets(line, sizeof(line), recon);
	fclose(recon);
	// strip newline
	char *pos = strchr(line, '\n');
	if (pos) {
		*pos = '\0';
	ESP_LOGI(TAG, "Read from file: '%s'", line);
	if (foo == NULL) {
		return;
	fgets(line, sizeof(line), foo);
	fclose(foo);
	// strip newline
	if (pos) {
		*pos = '\0';
	// Unmount FATFS
	ESP_LOGI(TAG, "Unmounting FAT filesystem");
	ESP_ERROR_CHECK( esp_vfs_fat_spiflash_unmount(base_path, s_wl_handle));
	ESP_LOGI(TAG, "Done");
	while(1){
		vTaskDelay(1000);
void print_dr(void)
	ESP_LOGI(TAG, "Directory content:");
	DIR *d;
	struct dirent *dir;
	d = opendir("/spiflash");
	if (d) {
		while ((dir = readdir(d)) != NULL) {
			ESP_LOGI(TAG, "%s\n", dir->d_name);
	closedir(d);
	DIR *theFolder = opendir("/spiflash");
	struct dirent *next_file;
	char filepath[256];
	while ( (next_file = readdir(theFolder)) != NULL )
		// build the path for each file in the folder
		sprintf(filepath, "%s/%s", "/spiflash", next_file->d_name);
		remove(filepath);
	closedir(theFolder);
/* report a zlib or i/o error */
void zerr(int ret)
    switch (ret) {
    case Z_ERRNO:
        ESP_LOGE(TAG, "Z err no");
    case Z_STREAM_ERROR:
    	ESP_LOGE(TAG, "Invalid compression level");
    case Z_DATA_ERROR:
    	ESP_LOGE(TAG, "Data error");
    case Z_MEM_ERROR:
    	ESP_LOGE(TAG, "Mem error");
    case Z_VERSION_ERROR:
    	ESP_LOGE(TAG, "Version error");
Here is the link to the git hub repo that was used: https://github.com/madler/zlib.
This is how you integrate it into your project:
Copy all the .c and .h files into a new folder in your components folder and put the .h files into a seperate include fodler. Then you will need to add some includes to some files (don't remember which ones but should be clear from exceptions) and finally you need to flash a new partition (for the file system I am using, which is the FatFS).
For the partition table: Copy and paste this into a "partitions.csv" file:
# Espressif ESP32 Partition Table
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1M,
storage, data, fat , 0x110000,1M
And save it in your project directory. Execute make menuconfig and go to Partition Table -> Partition Table (...) and select Custom partition table CSV.
The flasher will then use this as the new partition table including the new FatFS, storage partition with 1MB size.
Also NOTE: File names should be kept short. I don't know the exact number (Smth. like 10 maybe) but keep it short. Otherwise you have to change it in menuconfig to support long file names.
Any help on resolving the issues in the code is welcome.
jubueche
Re: zlib on esp32
Postby jubueche » Mon Feb 11, 2019 1:00 pm
UPDATE: This code actually works. Somehow I corrupted my board. I tried the same code on a different board and it worked. Let me know if you run into any trouble.
ESP_Angus
Re: zlib on esp32
Postby ESP_Angus » Mon Feb 11, 2019 11:21 pm
Nice work jubueche!
Something else which may be of interest, it's not widely advertised but the ESP32 ROM contains a copy of the "miniz" library, which is a reduced footprint zlib-compatible implementation:
https://github.com/espressif/esp-idf/bl ... om/miniz.h
It doesn't have as many features as zlib, though.
Users browsing this forum: No registered users and 40 guests
