Can LuaJIT be build for ESP32?
I didn't succeeded, and I cannot find any useful stuff on Google, why?
Re: Can LuaJIT be build for ESP32?
It's probably technically possible to make LuaJIT run on an ESP32, although the extra memory overhead of Just In Time compilation may stretch the available IRAM for doing useful things with the natively compiled Lua routines.
It would still need a lot of complex porting work as the "JIT" part of LuaJIT is platform-specific (emitting native instructions), and AFAIK noone has ported it the Xtensa architecture.
Have you looked at NodeMCU ESP32 support? Not fast enough in some way?
Yes, not fast enough, and troublesome(I like ffi) to bind C function
Unfortunately "easy" ffi type functionality requires dynamic shared library loading. This is something we also don't have on ESP32 at the moment, any C code needs to be compiled and statically linked into the "final" binary.
That said, it may worth discussing with the NodeMCU developers if there is any way to make integrating C code easier with that project.
Have you looked at using Sol2 / Sol3 for doing Lua bindings? I've used it (on another MCU platform, not ESP32) and it is pretty awesome.
I found the Sol2 on Github, it is great! Thanks
Users browsing this forum: No registered users and 236 guests
