memory_layout issue
georgecarlo
memory_layout issue
Postby georgecarlo » Sat Mar 16, 2019 12:59 pm
Hello Community,
I recently used a QUESTAR G702-001UB - GPS Module on esp32. I used kolban's esp32 gps snippets (https://github.com/nkolban/esp32-snippe ... re/gps/gps)
I get the following stuff, could'nt identify where's the problem.
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4544
ho 0 tail 12 room 4
load:0x40078000,len:10756
load:0x40080400,len:6320
entry 0x4008070c
I (92) cpu_start: Pro cpu up.
I (92) cpu_start: Application information:
I (92) cpu_start: Project name:     app-template
I (92) cpu_start: App version:      1
I (95) cpu_start: Compile time:     17:00:37
I (99) cpu_start: Compile date:     Mar 14 2019
I (103) cpu_start: ESP-IDF:          v3.3-beta1-136-g97eecfa-dirty
I (109) cpu_start: Single core mode
V (113) memory_layout: reserved range is 0x3f406650 - 0x3f406668
D (118) memory_layout: Checking 5 reserved memory ranges:
D (123) memory_layout: Reserved memory range 0x3ffae000 - 0x3ffae6e0
D (129) memory_layout: Reserved memory range 0x3ffb0000 - 0x3ffb2aa0
D (135) memory_layout: Reserved memory range 0x3ffe0000 - 0x3ffe0440
D (142) memory_layout: Reserved memory range 0x40070000 - 0x40078000
D (148) memory_layout: Reserved memory range 0x40080000 - 0x40088094
0x40080000: _WindowOverflow4 at /home/admatic/esp/esp-idf/components/freertos/xtensa_vectors.S:1685
D (154) memory_layout: Building list of available memory regions:
V (160) memory_layout: Examining memory region 0x3ffae000 - 0x3ffb0000
V (166) memory_layout: Start of region 0x3ffae000 - 0x3ffb0000 overlaps reserved 0x3ffae000 - 0x3ffae6e0
D (175) memory_layout: Available memory region 0x3ffae6e0 - 0x3ffb0000
V (181) memory_layout: Examining memory region 0x3ffb0000 - 0x3ffb8000
V (187) memory_layout: Start of region 0x3ffb0000 - 0x3ffb8000 overlaps reserved 0x3ffb0000 - 0x3ffb2aa0
D (197) memory_layout: Available memory region 0x3ffb2aa0 - 0x3ffb8000
V (203) memory_layout: Examining memory region 0x3ffb8000 - 0x3ffc0000
D (209) memory_layout: Available memory region 0x3ffb8000 - 0x3ffc0000
V (215) memory_layout: Examining memory region 0x3ffc0000 - 0x3ffc2000
D (222) memory_layout: Available memory region 0x3ffc0000 - 0x3ffc2000
V (228) memory_layout: Examining memory region 0x3ffc2000 - 0x3ffc4000
D (234) memory_layout: Available memory region 0x3ffc2000 - 0x3ffc4000
V (240) memory_layout: Examining memory region 0x3ffc4000 - 0x3ffc6000
D (247) memory_layout: Available memory region 0x3ffc4000 - 0x3ffc6000
V (253) memory_layout: Examining memory region 0x3ffc6000 - 0x3ffc8000
D (259) memory_layout: Available memory region 0x3ffc6000 - 0x3ffc8000
V (265) memory_layout: Examining memory region 0x3ffc8000 - 0x3ffca000
D (272) memory_layout: Available memory region 0x3ffc8000 - 0x3ffca000
V (278) memory_layout: Examining memory region 0x3ffca000 - 0x3ffcc000
D (284) memory_layout: Available memory region 0x3ffca000 - 0x3ffcc000
V (290) memory_layout: Examining memory region 0x3ffcc000 - 0x3ffce000
D (297) memory_layout: Available memory region 0x3ffcc000 - 0x3ffce000
V (303) memory_layout: Examining memory region 0x3ffce000 - 0x3ffd0000
D (309) memory_layout: Available memory region 0x3ffce000 - 0x3ffd0000
V (315) memory_layout: Examining memory region 0x3ffd0000 - 0x3ffd2000
D (322) memory_layout: Available memory region 0x3ffd0000 - 0x3ffd2000
V (328) memory_layout: Examining memory region 0x3ffd2000 - 0x3ffd4000
D (334) memory_layout: Available memory region 0x3ffd2000 - 0x3ffd4000
V (340) memory_layout: Examining memory region 0x3ffd4000 - 0x3ffd6000
D (347) memory_layout: Available memory region 0x3ffd4000 - 0x3ffd6000
V (353) memory_layout: Examining memory region 0x3ffd6000 - 0x3ffd8000
D (359) memory_layout: Available memory region 0x3ffd6000 - 0x3ffd8000
V (365) memory_layout: Examining memory region 0x3ffd8000 - 0x3ffda000
D (372) memory_layout: Available memory region 0x3ffd8000 - 0x3ffda000
V (378) memory_layout: Examining memory region 0x3ffda000 - 0x3ffdc000
D (384) memory_layout: Available memory region 0x3ffda000 - 0x3ffdc000
V (390) memory_layout: Examining memory region 0x3ffdc000 - 0x3ffde000
D (397) memory_layout: Available memory region 0x3ffdc000 - 0x3ffde000
V (403) memory_layout: Examining memory region 0x3ffde000 - 0x3ffe0000
D (409) memory_layout: Available memory region 0x3ffde000 - 0x3ffe0000
V (415) memory_layout: Examining memory region 0x3ffe0000 - 0x3ffe4000
V (422) memory_layout: Start of region 0x3ffe0000 - 0x3ffe4000 overlaps reserved 0x3ffe0000 - 0x3ffe0440
D (431) memory_layout: Available memory region 0x3ffe0440 - 0x3ffe4000
V (437) memory_layout: Examining memory region 0x3ffe4000 - 0x3ffe8000
D (443) memory_layout: Available memory region 0x3ffe4000 - 0x3ffe8000
V (450) memory_layout: Examining memory region 0x3ffe8000 - 0x3fff0000
D (456) memory_layout: Available memory region 0x3ffe8000 - 0x3fff0000
V (462) memory_layout: Examining memory region 0x3fff0000 - 0x3fff8000
D (468) memory_layout: Available memory region 0x3fff0000 - 0x3fff8000
V (475) memory_layout: Examining memory region 0x3fff8000 - 0x3fffc000
D (481) memory_layout: Available memory region 0x3fff8000 - 0x3fffc000
V (487) memory_layout: Examining memory region 0x3fffc000 - 0x40000000
D (493) memory_layout: Available memory region 0x3fffc000 - 0x40000000
V (500) memory_layout: Examining memory region 0x40070000 - 0x40078000
V (506) memory_layout: Region 0x40070000 - 0x40078000 inside of reserved 0x40070000 - 0x40078000
V (514) memory_layout: Examining memory region 0x40078000 - 0x40080000
D (521) memory_layout: Available memory region 0x40078000 - 0x40080000
V (527) memory_layout: Examining memory region 0x40080000 - 0x40082000
0x40082000: heap_caps_realloc at /home/admatic/esp/esp-idf/components/heap/heap_caps.c:307
V (533) memory_layout: Region 0x40080000 - 0x40082000 inside of reserved 0x40080000 - 0x40088094
V (542) memory_layout: Examining memory region 0x40082000 - 0x40084000
0x40084000: commonErrorHandler at /home/admatic/esp/esp-idf/components/esp32/panic.c:707
V (548) memory_layout: Region 0x40082000 - 0x40084000 inside of reserved 0x40080000 - 0x40088094
V (556) memory_layout: Examining memory region 0x40084000 - 0x40086000
0x40086000: prvDeleteTCB at /home/admatic/esp/esp-idf/components/freertos/tasks.c:4590
V (563) memory_layout: Region 0x40084000 - 0x40086000 inside of reserved 0x40080000 - 0x40088094
V (571) memory_layout: Examining memory region 0x40086000 - 0x40088000
0x40088000: multi_heap_register_impl at /home/admatic/esp/esp-idf/components/heap/multi_heap.c:336
V (577) memory_layout: Region 0x40086000 - 0x40088000 inside of reserved 0x40080000 - 0x40088094
V (586) memory_layout: Examining memory region 0x40088000 - 0x4008a000
V (592) memory_layout: Start of region 0x40088000 - 0x4008a000 overlaps reserved 0x40080000 - 0x40088094
D (601) memory_layout: Available memory region 0x40088094 - 0x4008a000
V (608) memory_layout: Examining memory region 0x4008a000 - 0x4008c000
D (614) memory_layout: Available memory region 0x4008a000 - 0x4008c000
V (620) memory_layout: Examining memory region 0x4008c000 - 0x4008e000
D (626) memory_layout: Available memory region 0x4008c000 - 0x4008e000
V (633) memory_layout: Examining memory region 0x4008e000 - 0x40090000
D (639) memory_layout: Available memory region 0x4008e000 - 0x40090000
V (645) memory_layout: Examining memory region 0x40090000 - 0x40092000
D (651) memory_layout: Available memory region 0x40090000 - 0x40092000
V (658) memory_layout: Examining memory region 0x40092000 - 0x40094000
D (664) memory_layout: Available memory region 0x40092000 - 0x40094000
V (670) memory_layout: Examining memory region 0x40094000 - 0x40096000
D (676) memory_layout: Available memory region 0x40094000 - 0x40096000
V (683) memory_layout: Examining memory region 0x40096000 - 0x40098000
D (689) memory_layout: Available memory region 0x40096000 - 0x40098000
V (695) memory_layout: Examining memory region 0x40098000 - 0x4009a000
D (701) memory_layout: Available memory region 0x40098000 - 0x4009a000
V (708) memory_layout: Examining memory region 0x4009a000 - 0x4009c000
D (714) memory_layout: Available memory region 0x4009a000 - 0x4009c000
V (720) memory_layout: Examining memory region 0x4009c000 - 0x4009e000
D (726) memory_layout: Available memory region 0x4009c000 - 0x4009e000
V (733) memory_layout: Examining memory region 0x4009e000 - 0x400a0000
D (739) memory_layout: Available memory region 0x4009e000 - 0x400a0000
I (745) heap_init: Initializing. RAM available for dynamic allocation:
D (751) heap_init: New heap initialised at 0x3ffae6e0
I (756) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
D (761) heap_init: New heap initialised at 0x3ffb2aa0
I (766) heap_init: At 3FFB2AA0 len 0002D560 (181 KiB): DRAM
I (771) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM
D (777) heap_init: New heap initialised at 0x40078000
I (782) heap_init: At 40078000 len 00008000 (32 KiB): IRAM
D (787) heap_init: New heap initialised at 0x40088094
I (792) heap_init: At 40088094 len 00017F6C (95 KiB): IRAM
I (797) cpu_start: Pro cpu start user code
D (808) clk: RTC_SLOW_CLK calibration value: 3231514
V (146) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (146) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (150) intr_alloc: Connected src 46 to int 2 (cpu 0)
V (155) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (161) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xC0E
D (169) intr_alloc: Connected src 57 to int 3 (cpu 0)
V (173) esp_dbg_stubs: esp_dbg_stubs_init stubs 3ffb1e88
V (179) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (184) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0x40E
D (192) intr_alloc: Connected src 24 to int 9 (cpu 0)
I (197) cpu_start: Starting scheduler on PRO CPU.
D (202) heap_init: New heap initialised at 0x3ffe0440
V (206) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (206) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (206) intr_alloc: Connected src 16 to int 12 (cpu 0)
D (225) gps: >> doGPS
V (227) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): checking args
V (227) intr_alloc: esp_intr_alloc_intrstatus (cpu 0): Args okay. Resulting flags 0xE
D (227) intr_alloc: Connected src 35 to int 13 (cpu 0)
Can you please guide me through this.
Thanks in advance.
WiFive
Re: memory_layout issue
Postby WiFive » Sun Mar 17, 2019 12:30 pm
Messages like this are just false detections by idf_monitor
georgecarlo
Postby georgecarlo » Mon Mar 18, 2019 4:41 am
Thanks for the reply.
Those are not my issues, gps lines(values from my gps sensor) are not given in the monitor, instead
I dont know what they mean. and how do i solve it.
WiFive
Postby WiFive » Mon Mar 18, 2019 6:07 am
Well the title of your post is "memory_layout issue". There are no errors shown. Are you sure there is serial data coming in on the correct pin?
Users browsing this forum: NurEng, uC_Jon and 129 guests
