hi
Please find the code in Image
The Heap Memory is getting low and low..
asprintf(&post_data, "%s,",pxMessage->minor);
asprintf(&post_data1, "%s",post_data);
These two lines are depleting the heap. I am freeing the memory by free()
kindly help ...
Heap memory depleting
- esp.png (14.82 KiB) Viewed 5210 times
Re: Heap memory depleting
asprintf() allocates memory from the heap each time it is called. In general, you need to call free() once for each time you call asprintf(). The primary issue is that you are calling asprintf(&post_data1) in your while loop without calling free(post_data1) in the same loop. This means you allocate 10 times but then only deallocate 1 time.
Additionally, you are overwriting the pointers post_data and post_data1 in your loop. This means that you will only ever free the last allocation, without freeing all the others. Think of it something like this:
char* test;
test = allocate_some_memory();
free(test);
So, make sure that every time you call an allocating function like malloc, calloc, asprintf, etc. you also call free on the pointer that is returned. It must be the same pointer or you risk losing memory, or double freeing memory, which will cause a crash.
Jason
thanks
Yes figured it out ............
Users browsing this forum: No registered users and 138 guests
