ESP_LOGI causes to crash
arunbm123
Postby arunbm123 » Sun Mar 24, 2019 4:52 pm
hello friends
Why the line ESP_LOGI(TAG, "============inside blink_task ============! ");
caused esp32 to crash..
what is reason
void blink_task(void *pvParameter)
    /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
       muxed to GPIO on reset already, but some default to other
       functions and need to be switched to GPIO. Consult the
       Technical Reference for a list of pads and their default
       functions.)
    gpio_pad_select_gpio(BLINK_GPIO);
    /* Set the GPIO as a push/pull output */
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
    while(1) {
      [b]  ESP_LOGI(TAG,  "============inside blink_task ============! ");[/b]
        /* Blink off (output low) */
        gpio_set_level(BLINK_GPIO, 0);
		vTaskDelay(10000 / portTICK_PERIOD_MS);
        /* Blink on (output high) */
        gpio_set_level(BLINK_GPIO, 1);
		vTaskDelay(5000 / portTICK_PERIOD_MS);
ESP_krzychb
Contact:
Re: ESP_LOGI causes to crash
Postby ESP_krzychb » Sun Mar 24, 2019 5:45 pm
Hi arunbm123,
You may need to increase task stack size.
arunbm123
Postby arunbm123 » Mon Mar 25, 2019 3:17 am
hello krzychb
Thanks krzychb , This solved the problem.
Users browsing this forum: Bing [Bot], iw2lsi and 18 guests
