Get SD card free space not updating?
gunar.kroeger
Postby gunar.kroeger » Fri Mar 29, 2019 7:43 pm
I am able to read SD card free space by using this function:
Code: Untitled.c Select all
bool SD_getFreeSpace(uint32_t *tot, uint32_t *free)
FATFS *fs;
DWORD fre_clust, fre_sect, tot_sect;
/* Get volume information and free clusters of drive 0 */
if(f_getfree("0:", &fre_clust, &fs) == FR_OK)
/* Get total sectors and free sectors */
tot_sect = (fs->n_fatent - 2) * fs->csize;
fre_sect = fre_clust * fs->csize;
*tot = tot_sect / 2;
*free = fre_sect / 2;
/* Print the free space (assuming 512 bytes/sector) */
ESP_LOGD(TAG, "%10lu KiB total drive space. %10lu KiB available.", *tot, *free);
return true;
return false;
But even if I remove the SD card after I mounted the card I still get the same values as before removing the card. Is there a way to get free and total space without unmounting and remounting the SD card? I wish to check at least if the SD card has been removed.
Currently I am opening and closing an empty file to do this.
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
pilidfast-mail
Re: Get SD card free space not updating?
Postby pilidfast-mail » Sat Apr 06, 2019 8:09 am
That's the software bug, nothing to do with hardware. Report the issue, next update might (will) solve it.
gunar.kroeger
Postby gunar.kroeger » Mon Apr 08, 2019 3:20 pm
https://github.com/espressif/esp-idf/issues/3278
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bing [Bot], PerplexityBot, Qwantbot and 2 guests
