eMMC module
marchingband
Re: eMMC module
Postby marchingband » Fri Apr 05, 2019 5:13 pm
here is an image of the circuit and adapters I am using.
marchingband
Re: eMMC module
Postby marchingband » Fri Apr 05, 2019 5:53 pm
these are the connections I am using, same as suggested in the sd_card example read_me, all with 10k pull-ups.
GPIO14 -> CLK
GPIO15 -> CMD
GPIO2 -> D0
GPIO4 -> D1
GPIO12 -> D2
GPIO13 -> D3
ESP_igrr
Re: eMMC module
Postby ESP_igrr » Sat Apr 06, 2019 1:09 am
Based on the log, the difference between the SD and eMMC cases is that for eMMC case, DDR mode is used. You can try disabling the DDR mode (see host.flags), and see if you get the correct result this way.
We'll order those eMMC parts and do a test on our side.
Another thing to try would be to fill the buffer with some bit patterns (0x55AA55AA or like) and print out the contents of the output buffer, not just the first byte. That might also give some direction to investigate.
marchingband
Re: eMMC module
Postby marchingband » Sat Apr 06, 2019 6:20 pm
I will try those ideas out.
Thank you for your help, please let me know your findings!
In the meantime do you have a list of known compatible eMMC module/breakout/adapter boards?
marchingband
Re: eMMC module
Postby marchingband » Tue Apr 09, 2019 1:06 am
I use 1-line mode to write numbers from 0-255 to the card.
I use 4-line mode to read them back, using this code:
#define BYTE_TO_BINARY(byte)  \
  (byte & 0x80 ? '1' : '0'), \
  (byte & 0x40 ? '1' : '0'), \
  (byte & 0x20 ? '1' : '0'), \
  (byte & 0x10 ? '1' : '0'), \
  (byte & 0x08 ? '1' : '0'), \
  (byte & 0x04 ? '1' : '0'), \
  (byte & 0x02 ? '1' : '0'), \
  (byte & 0x01 ? '1' : '0')
void app_main(void)
  sdmmc_host_init();
  sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
  slot_config.width = 4;
  //slot_config.width = 1;
  sdmmc_host_init_slot(SDMMC_HOST_SLOT_1, &slot_config);
  sdmmc_host_t host = SDMMC_HOST_DEFAULT();
  host.max_freq_khz = SDMMC_FREQ_PROBING;
  sdmmc_card_t card;
  sdmmc_card_init(&host,&card);
  // sdmmc_host_set_bus_ddr_mode(SDMMC_HOST_SLOT_1, false);
  sdmmc_card_print_info(stdout, &card);
  gpio_set_pull_mode(15, GPIO_PULLUP_ONLY);   // CMD, needed in 4- and 1- line modes
  gpio_set_pull_mode(2, GPIO_PULLUP_ONLY);    // D0, needed in 4- and 1-line modes
  gpio_set_pull_mode(4, GPIO_PULLUP_ONLY);    // D1, needed in 4-line mode only
  gpio_set_pull_mode(12, GPIO_PULLUP_ONLY);   // D2, needed in 4-line mode only
  gpio_set_pull_mode(13, GPIO_PULLUP_ONLY);   // D3, needed in 4- and 1-line modes
  static uint8_t data[256] = {0};
  static uint8_t buff[256] = {0};
  for(uint16_t i=0;i<256;i++){
    data[i]=i;
  // ESP_ERROR_CHECK_WITHOUT_ABORT( sdmmc_write_sectors(&card, data, 1000, 1) );
  ESP_ERROR_CHECK_WITHOUT_ABORT( sdmmc_read_sectors(&card, buff, 1000, 1) );
    uint8_t return1 = buff[i];
    printf("%d \n%c%c%c%c %c%c%c%c \n%c%c%c%c %c%c%c%c\n\n",return1,BYTE_TO_BINARY(i),BYTE_TO_BINARY(return1));
and get this result, where the top member is the correct bits, bottom member is whats read from the card:
Type: MMC
Speed: 400 kHz
CSD: ver=3, sector_size=512, capacity=15269888 read_bl_len=9
D (477) sdmmc_req: process_data_status: error 0x109 (status=00000080)
E (487) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x109
ESP_ERROR_CHECK_WITHOUT_ABORT failed: esp_err_t 0x109 (ESP_ERR_INVALID_CRC) at 0x40083e5b
0x40083e5b: _esp_error_check_failed_without_abort at /Users/andymarch/esp/esp-idf/components/esp32/panic.c:715
file: "/Users/andymarch/esp/sd_tests/main/main.c" line 313
func: app_main
expression: sdmmc_read_sectors(&card, buff, 1000, 1)
I (507) sd_tests: 0
0000 0000
0000 0000
I (517) sd_tests: 1
0000 0001
0000 0001
I (517) sd_tests: 2
0000 0010
0000 0010
I (527) sd_tests: 3
0000 0011
0000 0011
I (527) sd_tests: 4
0000 0100
0000 1100
I (537) sd_tests: 5
0000 0101
0000 1101
I (537) sd_tests: 6
0000 0110
0000 1110
I (547) sd_tests: 7
0000 0111
0000 1111
I (547) sd_tests: 8
0000 1000
0000 1100
I (557) sd_tests: 9
0000 1001
0000 1101
I (557) sd_tests: 10
0000 1010
0000 1110
I (567) sd_tests: 11
0000 1011
0000 1111
I (567) sd_tests: 12
0000 1100
0000 1100
I (577) sd_tests: 13
0000 1101
0000 1101
I (587) sd_tests: 14
0000 1110
0000 1110
I (587) sd_tests: 15
0000 1111
0000 1111
I (597) sd_tests: 16
0001 0000
0001 0000
I (597) sd_tests: 17
0001 0001
0001 0001
I (607) sd_tests: 18
0001 0010
0001 0010
I (607) sd_tests: 19
0001 0011
0001 0011
I (617) sd_tests: 20
0001 0100
0001 1100
I (617) sd_tests: 21
0001 0101
0001 1101
I (627) sd_tests: 22
0001 0110
0001 1110
I (627) sd_tests: 23
0001 0111
0001 1111
I (637) sd_tests: 24
0001 1000
0001 1100
I (637) sd_tests: 25
0001 1001
0001 1101
I (647) sd_tests: 26
0001 1010
0001 1110
I (647) sd_tests: 27
0001 1011
0001 1111
I (657) sd_tests: 28
0001 1100
0001 1100
I (657) sd_tests: 29
0001 1101
0001 1101
I (667) sd_tests: 30
0001 1110
0001 1110
I (677) sd_tests: 31
0001 1111
0001 1111
I (677) sd_tests: 32
0010 0000
0010 0000
I (687) sd_tests: 33
0010 0001
0010 0001
I (687) sd_tests: 34
0010 0010
0010 0010
I (697) sd_tests: 35
0010 0011
0010 0011
I (697) sd_tests: 36
0010 0100
0010 1100
I (707) sd_tests: 37
0010 0101
0010 1101
I (707) sd_tests: 38
0010 0110
0010 1110
I (717) sd_tests: 39
0010 0111
0010 1111
I (717) sd_tests: 40
0010 1000
0010 1100
I (727) sd_tests: 41
0010 1001
0010 1101
I (727) sd_tests: 42
0010 1010
0010 1110
I (737) sd_tests: 43
0010 1011
0010 1111
I (737) sd_tests: 44
0010 1100
0010 1100
I (747) sd_tests: 45
0010 1101
0010 1101
I (747) sd_tests: 46
0010 1110
0010 1110
I (757) sd_tests: 47
0010 1111
0010 1111
I (767) sd_tests: 48
0011 0000
0011 0000
I (767) sd_tests: 49
0011 0001
0011 0001
I (777) sd_tests: 50
0011 0010
0011 0010
I (777) sd_tests: 51
0011 0011
0011 0011
I (787) sd_tests: 52
0011 0100
0011 1100
I (787) sd_tests: 53
0011 0101
0011 1101
I (797) sd_tests: 54
0011 0110
0011 1110
I (797) sd_tests: 55
0011 0111
0011 1111
I (807) sd_tests: 56
0011 1000
0011 1100
I (807) sd_tests: 57
0011 1001
0011 1101
I (817) sd_tests: 58
0011 1010
0011 1110
I (817) sd_tests: 59
0011 1011
0011 1111
I (827) sd_tests: 60
0011 1100
0011 1100
I (827) sd_tests: 61
0011 1101
0011 1101
I (837) sd_tests: 62
0011 1110
0011 1110
I (837) sd_tests: 63
0011 1111
0011 1111
I (847) sd_tests: 64
0100 0000
1100 0000
I (857) sd_tests: 65
0100 0001
1100 0001
I (857) sd_tests: 66
0100 0010
1100 0010
I (867) sd_tests: 67
0100 0011
1100 0011
I (867) sd_tests: 68
0100 0100
1100 1100
I (877) sd_tests: 69
0100 0101
1100 1101
I (877) sd_tests: 70
0100 0110
1100 1110
I (887) sd_tests: 71
0100 0111
1100 1111
I (887) sd_tests: 72
0100 1000
1100 1100
I (897) sd_tests: 73
0100 1001
1100 1101
I (897) sd_tests: 74
0100 1010
1100 1110
I (907) sd_tests: 75
0100 1011
1100 1111
I (907) sd_tests: 76
0100 1100
1100 1100
I (917) sd_tests: 77
0100 1101
1100 1101
I (917) sd_tests: 78
0100 1110
1100 1110
I (927) sd_tests: 79
0100 1111
1100 1111
I (927) sd_tests: 80
0101 0000
1101 0000
I (937) sd_tests: 81
0101 0001
1101 0001
I (947) sd_tests: 82
0101 0010
1101 0010
I (947) sd_tests: 83
0101 0011
1101 0011
I (957) sd_tests: 84
0101 0100
1101 1100
I (957) sd_tests: 85
0101 0101
1101 1101
I (967) sd_tests: 86
0101 0110
1101 1110
I (967) sd_tests: 87
0101 0111
1101 1111
I (977) sd_tests: 88
0101 1000
1101 1100
I (977) sd_tests: 89
0101 1001
1101 1101
I (987) sd_tests: 90
0101 1010
1101 1110
I (987) sd_tests: 91
0101 1011
1101 1111
I (997) sd_tests: 92
0101 1100
1101 1100
I (997) sd_tests: 93
0101 1101
1101 1101
I (1007) sd_tests: 94
0101 1110
1101 1110
I (1007) sd_tests: 95
0101 1111
1101 1111
I (1017) sd_tests: 96
0110 0000
1110 0000
I (1027) sd_tests: 97
0110 0001
1110 0001
I (1027) sd_tests: 98
0110 0010
1110 0010
I (1037) sd_tests: 99
0110 0011
1110 0011
I (1037) sd_tests: 100
0110 0100
1110 1100
I (1047) sd_tests: 101
0110 0101
1110 1101
I (1047) sd_tests: 102
0110 0110
1110 1110
I (1057) sd_tests: 103
0110 0111
1110 1111
I (1057) sd_tests: 104
0110 1000
1110 1100
I (1067) sd_tests: 105
0110 1001
1110 1101
I (1067) sd_tests: 106
0110 1010
1110 1110
I (1077) sd_tests: 107
0110 1011
1110 1111
I (1087) sd_tests: 108
0110 1100
1110 1100
I (1087) sd_tests: 109
0110 1101
1110 1101
I (1097) sd_tests: 110
0110 1110
1110 1110
I (1097) sd_tests: 111
0110 1111
1110 1111
I (1107) sd_tests: 112
0111 0000
1111 0000
I (1107) sd_tests: 113
0111 0001
1111 0001
I (1117) sd_tests: 114
0111 0010
1111 0010
I (1117) sd_tests: 115
0111 0011
1111 0011
I (1127) sd_tests: 116
0111 0100
1111 1100
I (1127) sd_tests: 117
0111 0101
1111 1101
I (1137) sd_tests: 118
0111 0110
1111 1110
I (1147) sd_tests: 119
0111 0111
1111 1111
I (1147) sd_tests: 120
0111 1000
1111 1100
I (1157) sd_tests: 121
0111 1001
1111 1101
I (1157) sd_tests: 122
0111 1010
1111 1110
I (1167) sd_tests: 123
0111 1011
1111 1111
I (1167) sd_tests: 124
0111 1100
1111 1100
I (1177) sd_tests: 125
0111 1101
1111 1101
I (1177) sd_tests: 126
0111 1110
1111 1110
I (1187) sd_tests: 127
0111 1111
1111 1111
I (1187) sd_tests: 128
1000 0000
1100 0000
I (1197) sd_tests: 129
1000 0001
1100 0001
I (1207) sd_tests: 130
1000 0010
1100 0010
I (1207) sd_tests: 131
1000 0011
1100 0011
I (1217) sd_tests: 132
1000 0100
1100 1100
I (1217) sd_tests: 133
1000 0101
1100 1101
I (1227) sd_tests: 134
1000 0110
1100 1110
I (1227) sd_tests: 135
1000 0111
1100 1111
I (1237) sd_tests: 136
1000 1000
1100 1100
I (1237) sd_tests: 137
1000 1001
1100 1101
I (1247) sd_tests: 138
1000 1010
1100 1110
I (1247) sd_tests: 139
1000 1011
1100 1111
I (1257) sd_tests: 140
1000 1100
1100 1100
I (1267) sd_tests: 141
1000 1101
1100 1101
I (1267) sd_tests: 142
1000 1110
1100 1110
I (1277) sd_tests: 143
1000 1111
1100 1111
I (1277) sd_tests: 144
1001 0000
1101 0000
I (1287) sd_tests: 145
1001 0001
1101 0001
I (1287) sd_tests: 146
1001 0010
1101 0010
I (1297) sd_tests: 147
1001 0011
1101 0011
I (1297) sd_tests: 148
1001 0100
1101 1100
I (1307) sd_tests: 149
1001 0101
1101 1101
I (1307) sd_tests: 150
1001 0110
1101 1110
I (1317) sd_tests: 151
1001 0111
1101 1111
I (1327) sd_tests: 152
1001 1000
1101 1100
I (1327) sd_tests: 153
1001 1001
1101 1101
I (1337) sd_tests: 154
1001 1010
1101 1110
I (1337) sd_tests: 155
1001 1011
1101 1111
I (1347) sd_tests: 156
1001 1100
1101 1100
I (1347) sd_tests: 157
1001 1101
1101 1101
I (1357) sd_tests: 158
1001 1110
1101 1110
I (1357) sd_tests: 159
1001 1111
1101 1111
I (1367) sd_tests: 160
1010 0000
1110 0000
I (1377) sd_tests: 161
1010 0001
1110 0001
I (1377) sd_tests: 162
1010 0010
1110 0010
I (1387) sd_tests: 163
1010 0011
1110 0011
I (1387) sd_tests: 164
1010 0100
1110 1100
I (1397) sd_tests: 165
1010 0101
1110 1101
I (1397) sd_tests: 166
1010 0110
1110 1110
I (1407) sd_tests: 167
1010 0111
1110 1111
I (1407) sd_tests: 168
1010 1000
1110 1100
I (1417) sd_tests: 169
1010 1001
1110 1101
I (1417) sd_tests: 170
1010 1010
1110 1110
I (1427) sd_tests: 171
1010 1011
1110 1111
I (1437) sd_tests: 172
1010 1100
1110 1100
I (1437) sd_tests: 173
1010 1101
1110 1101
I (1447) sd_tests: 174
1010 1110
1110 1110
I (1447) sd_tests: 175
1010 1111
1110 1111
I (1457) sd_tests: 176
1011 0000
1111 0000
I (1457) sd_tests: 177
1011 0001
1111 0001
I (1467) sd_tests: 178
1011 0010
1111 0010
I (1467) sd_tests: 179
1011 0011
1111 0011
I (1477) sd_tests: 180
1011 0100
1111 1100
I (1477) sd_tests: 181
1011 0101
1111 1101
I (1487) sd_tests: 182
1011 0110
1111 1110
I (1497) sd_tests: 183
1011 0111
1111 1111
I (1497) sd_tests: 184
1011 1000
1111 1100
I (1507) sd_tests: 185
1011 1001
1111 1101
I (1507) sd_tests: 186
1011 1010
1111 1110
I (1517) sd_tests: 187
1011 1011
1111 1111
I (1517) sd_tests: 188
1011 1100
1111 1100
I (1527) sd_tests: 189
1011 1101
1111 1101
I (1527) sd_tests: 190
1011 1110
1111 1110
I (1537) sd_tests: 191
1011 1111
1111 1111
I (1537) sd_tests: 192
1100 0000
1100 0000
I (1547) sd_tests: 193
1100 0001
1100 0001
I (1557) sd_tests: 194
1100 0010
1100 0010
I (1557) sd_tests: 195
1100 0011
1100 0011
I (1567) sd_tests: 196
1100 0100
1100 1100
I (1567) sd_tests: 197
1100 0101
1100 1101
I (1577) sd_tests: 198
1100 0110
1100 1110
I (1577) sd_tests: 199
1100 0111
1100 1111
I (1587) sd_tests: 200
1100 1000
1100 1100
I (1587) sd_tests: 201
1100 1001
1100 1101
I (1597) sd_tests: 202
1100 1010
1100 1110
I (1597) sd_tests: 203
1100 1011
1100 1111
I (1607) sd_tests: 204
1100 1100
1100 1100
I (1617) sd_tests: 205
1100 1101
1100 1101
I (1617) sd_tests: 206
1100 1110
1100 1110
I (1627) sd_tests: 207
1100 1111
1100 1111
I (1627) sd_tests: 208
1101 0000
1101 0000
I (1637) sd_tests: 209
1101 0001
1101 0001
I (1637) sd_tests: 210
1101 0010
1101 0010
I (1647) sd_tests: 211
1101 0011
1101 0011
I (1647) sd_tests: 212
1101 0100
1101 1100
I (1657) sd_tests: 213
1101 0101
1101 1101
I (1657) sd_tests: 214
1101 0110
1101 1110
I (1667) sd_tests: 215
1101 0111
1101 1111
I (1677) sd_tests: 216
1101 1000
1101 1100
I (1677) sd_tests: 217
1101 1001
1101 1101
I (1687) sd_tests: 218
1101 1010
1101 1110
I (1687) sd_tests: 219
1101 1011
1101 1111
I (1697) sd_tests: 220
1101 1100
1101 1100
I (1697) sd_tests: 221
1101 1101
1101 1101
I (1707) sd_tests: 222
1101 1110
1101 1110
I (1707) sd_tests: 223
1101 1111
1101 1111
I (1717) sd_tests: 224
1110 0000
1110 0000
I (1727) sd_tests: 225
1110 0001
1110 0001
I (1727) sd_tests: 226
1110 0010
1110 0010
I (1737) sd_tests: 227
1110 0011
1110 0011
I (1737) sd_tests: 228
1110 0100
1110 1100
I (1747) sd_tests: 229
1110 0101
1110 1101
I (1747) sd_tests: 230
1110 0110
1110 1110
I (1757) sd_tests: 231
1110 0111
1110 1111
I (1757) sd_tests: 232
1110 1000
1110 1100
I (1767) sd_tests: 233
1110 1001
1110 1101
I (1767) sd_tests: 234
1110 1010
1110 1110
I (1777) sd_tests: 235
1110 1011
1110 1111
I (1787) sd_tests: 236
1110 1100
1110 1100
I (1787) sd_tests: 237
1110 1101
1110 1101
I (1797) sd_tests: 238
1110 1110
1110 1110
I (1797) sd_tests: 239
1110 1111
1110 1111
I (1807) sd_tests: 240
1111 0000
1111 0000
I (1807) sd_tests: 241
1111 0001
1111 0001
I (1817) sd_tests: 242
1111 0010
1111 0010
I (1817) sd_tests: 243
1111 0011
1111 0011
I (1827) sd_tests: 244
1111 0100
1111 1100
I (1827) sd_tests: 245
1111 0101
1111 1101
I (1837) sd_tests: 246
1111 0110
1111 1110
I (1847) sd_tests: 247
1111 0111
1111 1111
I (1847) sd_tests: 248
1111 1000
1111 1100
I (1857) sd_tests: 249
1111 1001
1111 1101
I (1857) sd_tests: 250
1111 1010
1111 1110
I (1867) sd_tests: 251
1111 1011
1111 1111
I (1867) sd_tests: 252
1111 1100
1111 1100
I (1877) sd_tests: 253
1111 1101
1111 1101
I (1877) sd_tests: 254
1111 1110
1111 1110
I (1887) sd_tests: 255
1111 1111
1111 1111
Although it appears there is a pattern I do not know enough about the workings of the driver code to debug.
The errors are consistent over multiples resets.
Where could I start?
Thanks!!!!
marchingband
Re: eMMC module
Postby marchingband » Tue Apr 09, 2019 1:13 am
the errors are always in the 3rd,4th,7th or 8th bit ... does this again point at signal integrity on 2 of the 4 lines?
marchingband
Re: eMMC module
Postby marchingband » Tue Apr 09, 2019 1:58 am
it appears that BIT3 and BIT4 are OR'd,
likewise BIT7 and BIT8 are OR'd
marchingband
Re: eMMC module
Postby marchingband » Wed Apr 10, 2019 5:48 pm
Does cross-talk like this between signal lines point at the same signal integrity issues as before, in your experience? Or does this look like a driver issue?
thanks!
ESP_igrr
Re: eMMC module
Postby ESP_igrr » Thu Apr 25, 2019 1:14 am
If you disable the DDR mode in sdmmc_host_t::flags, does this change the error pattern?
The interesting thing seems to be that the write command seems to succeed in 4-line mode, but read command fails in 4-line mode. I can't really explain how this may happen, as any signal issues should be symmetrical (unless they also depend on drive strength, but that seems to be unlikely).
Regarding whether the issue is in the hardware or in the driver: the driver itself doesn't deal with data directly. It sets up the hardware and then all the data is sent by DMA. So this is either a hardware issue, or a driver bug in that it misconfigures the hardware. However any timing misconfiguration would likely affect all the pins, not just two of them. So overall it does look like a hardware issue to me. Perhaps a short somewhere between the two signal lines? The error pattern resembles a "wired OR"...
marchingband
Re: eMMC module
Postby marchingband » Thu Apr 25, 2019 8:29 am
I am happy to report it was indeed a short. The culprit was the sd->eMMC adapter card. The traces are very close together and short where they contact the micro->sd adapter. There is a sweet spot that prevents the short but keeps the connections intact.
I am not sure why I didn't think to check for a short when I saw the or'd bits, and I am very grateful for your assistance. The eMMC works wonderfully now in 4-BIT mode. It reads a single sector in about 260 us, just fast enough for my use case :D
Users browsing this forum: No registered users and 46 guests
