LyraT 4.3 records peak noise with rare chance in repeating recording
donaldzeng
Postby donaldzeng » Wed May 29, 2019 1:13 pm
I am testing with a LyraT 4.3 board, and running example pipeline_wav_sdcard. Firstly the origin example was running great and record one .wav file each time I ran it.
Then I wrapped it to record repeatedly with an increasing number as .wav filename. Something strange was discovered that with a small chance, the L or R channel data may be corrupted with pike noise. Say I ran for 1000 recording files, I might get 20 to 25 files with corrupted data, either L or R. I never see L and R corrupted at the same time.
Some investigation has been done. I am pretty sure the whole modification is just for wrapping recording into a separate task, and not relative to pipeline itself. Looking into the .wav data, it seems the corrupted voice data caused by slipping 1 bit, and then LSB of one is regarded as MSB of the next.
Did someone ever see this phenomenon, or even have an answer/solution in place? Thanks a lot.
donaldzeng
Re: LyraT 4.3 records peak noise with rare chance in repeating recording
Postby donaldzeng » Wed May 29, 2019 2:44 pm
with some corrupted .wav diagrams.
the diagram of L channel data corrupted
the diagram of R channel data corrupted
the diagram of zoom-in detail data corrupted
jason.mao
Postby jason.mao » Thu May 30, 2019 1:27 am
Hi donaldzeng,
Could you post you wav file at here? Does continuous recording different file can be reproduced?
donaldzeng
Postby donaldzeng » Thu May 30, 2019 1:51 am
Thanks for your quick reply. The problem, yes, can be reproduced in every long-time run, perhaps 1 or 2 time out of 100 times recording. I linked a wav file here: http://120.25.201.118/lotus/files/espbin/1304.wav.
