Executing action: all (aliases: build)
Running ninja in directory c:\users\baps\desktop\esp\examples\pipeline_a2dp_source_stream\build
Executing "ninja all"...
ninja: error: '../partitions.csv', needed by 'partition_table/partition-table.bin', missing and no known rule to make it
ninja failed with exit code 1
I am trying to compile and build project provided for the ESP32 lyra base audio board.
however i had compiled the project successfully before, but getting error when compiling again.
Is there any way to get rid of it.
any suggestions are invited.
Thanks in advance.
partition table error
Re: partition table error
Seems you used to have a custom partition setup in a partitions.csv, but that file is missing now. Either restore it, or select a non-custom partition setup using menuconfig.
Something similar has happened.
In first trial, I used default program and it was working well. However I was using usb hub for power supply so i faced rebooting issue so i thought it might be because i was recently playing with wifi memory. but when i delete modified program and run the origional program again. It got compiled and build.
It worked for me but what i am trying to understand is how to create partition table binary files for esp32 by manually.
Users browsing this forum: No registered users and 41 guests
