ADF 2.4
File: i2s_stream.c
Function: audio_element_handle_t i2s_stream_init(i2s_stream_cfg_t *config);
Line: 401
i2s_mclk_gpio_select(i2s->config.i2s_port, GPIO_NUM_0);
I do not even wish to use mclk output. Will Espressif accept a PR that introduces a function that allows i2s_stream_init with custom pins without requiring board config implementation and that does not hard code mclk?
audio_element_handle_t i2s_stream_init(i2s_stream_cfg_t *config, i2s_pin_config_t* pin_config);
How has this bug survived so long. Does no one else use ADF with custom board?
i2s_stream_init hard codes mclk to gpio0 BUG?
Users browsing this forum: No registered users and 56 guests
