i can run the voip app example without any problem.
https://github.com/espressif/esp-adf/tr ... ocols/voip
is there any way to get caller id when there is incoming call event to esp32.
thank you.
how to get caller id in VoIP example.
Re: how to get caller id in VoIP example.
in the voip app v2.4 release https://github.com/espressif/esp-adf/tr ... mples/voip
we can get the caller id using this line of code
how can i get that caller id in the current master branch?
ESP_LOGI(TAG, "ringing... RemotePhoneNum %s", (char *)event->data);
static int _sip_event_handler(sip_event_msg_t *event)
ip4_addr_t ip;
switch ((int)event->type) {
case SIP_EVENT_REQUEST_NETWORK_STATUS:
ESP_LOGD(TAG, "SIP_EVENT_REQUEST_NETWORK_STATUS");
ip = _get_network_ip();
if (ip.addr) {
return true;
return ESP_OK;
case SIP_EVENT_REQUEST_NETWORK_IP:
ESP_LOGD(TAG, "SIP_EVENT_REQUEST_NETWORK_IP");
int ip_len = sprintf((char *)event->data, "%s", ip4addr_ntoa(&ip));
return ip_len;
case SIP_EVENT_REGISTERED:
ESP_LOGI(TAG, "SIP_EVENT_REGISTERED");
audio_player_int_tone_play(tone_uri[TONE_TYPE_SERVER_CONNECT]);
case SIP_EVENT_RINGING:
audio_player_int_tone_play(tone_uri[TONE_TYPE_ALARM]);
case SIP_EVENT_INVITING:
ESP_LOGI(TAG, "SIP_EVENT_INVITING Remote Ring...");
case SIP_EVENT_ERROR:
ESP_LOGI(TAG, "SIP_EVENT_ERROR");
case SIP_EVENT_HANGUP:
ESP_LOGI(TAG, "SIP_EVENT_HANGUP");
case SIP_EVENT_AUDIO_SESSION_BEGIN:
ESP_LOGI(TAG, "SIP_EVENT_AUDIO_SESSION_BEGIN");
recorder_pipeline_open();
player_pipeline_open();
audio_pipeline_run(player);
audio_pipeline_run(recorder);
case SIP_EVENT_AUDIO_SESSION_END:
ESP_LOGI(TAG, "SIP_EVENT_AUDIO_SESSION_END");
audio_pipeline_stop(player);
audio_pipeline_wait_for_stop(player);
audio_pipeline_deinit(player);
audio_pipeline_stop(recorder);
audio_pipeline_wait_for_stop(recorder);
audio_pipeline_deinit(recorder);
case SIP_EVENT_READ_AUDIO_DATA:
#if (DEBUG_AEC_INPUT || DEBUG_AEC_OUTPUT)
vTaskDelay(20 / portTICK_PERIOD_MS);
memset((char *)event->data, 0, event->data_len);
return event->data_len;
#else
return raw_stream_read(raw_read, (char *)event->data, event->data_len);
#endif
case SIP_EVENT_WRITE_AUDIO_DATA:
return raw_stream_write(raw_write, (char *)event->data, event->data_len);
case SIP_EVENT_READ_DTMF:
ESP_LOGI(TAG, "SIP_EVENT_READ_DTMF ID : %d ", ((char *)event->data)[0]);
return 0;
Users browsing this forum: No registered users and 67 guests
