BUG / Workaround : Mesh and smart config
Hi all
I am struggling to get smart config working with my mesh. I deliberately give it an incorrect said which it detects and sends event "no parent". When I receive this event I start the smart config process as per the example and get the ssid and password that I send it. Once received on SC_STATUS_LINK I call esp_mesh_set_router and it appears to hang (no output). I have tried stopping the smart config before it and it behaves the same. I have also tried switching off mesh self organising once I detect no parent and then back on before calling the set router and this seems to stop the smart config working.
Anyone been able to get this working?
Thanks in advance
Lee.
Thanks in advance
Lee.
Re: Mesh and smart config
Hi leenowell,
We will have a discussion on this API.
Currently, you can try `esp_mesh_set_self_organized(true,true)` after set router, and allow channel switch when set config.
Thanks I have tried this before and unfortunately it doesn't seem to work. In my test I turned self organising off first then did the smart config session and when the new details came back set the router info and then switched it back on.
Re: BUG / Workaround : Mesh and smart config
After a lot of trial and error, I have a workaround but think there is an underlying bug. I am using the smart config example code as a template.
If I call the function to do the smart config in the mesh event handler (when no parent found) either as a function call or by creating a new task, the smart config appears to get the details (fires SC_STATUS_LINK) but calling esp_mesh_set_router doesn't seem to work - there is no activity on serial output. Also, it never fires event SC_STATUS_LINK_OVER. I also tried switching the router config using the wifi calls (surrounded by switching self organising off before it and then back on after it) that are in the example and this fails too sometimes core dumping
My workaround is to create a task in the mesh event handler to start the smart config process and waits for this task to set a bit to say it has got the data. The smart config task then stores the SSID and password in global variables when SC_STATUS_LINK is fired and then stops the smart config process, deletes the task, and sets the bit to say it has done it. On detecting the bit has been set, the mesh event handler reads the global variables and calls esp_mesh_set_router. This seems to work fine but adds unnecessary complexity to the code design. Any ideas why the switching in the smart config event handler as in the example doesn't work with mesh?
Code in the mesh event handler is...
Smart config code is
Code for the event handler
EventBits_t uxBits;
bool bSmartConfigDone = false;
ESP_LOGI(HOMEIOT_TAG, "OnMeshNoParent: No parent found starting Smart Config");
xTaskCreate(DoSmartConfig, "DoSmartConfig", 4096, NULL, 3, NULL);
while (!bSmartConfigDone)
// Wait for the Smart Config to set the get data bit to indicate it has got router info
uxBits = xEventGroupWaitBits(s_wifi_event_group, SMARTCONFIG_GOT_DATA_BIT, true, false, portMAX_DELAY);
if(uxBits & SMARTCONFIG_GOT_DATA_BIT)
ESP_LOGI(HOMEIOT_TAG, "OnMeshNoParent: Received notification Smart Config has set data");
mesh_router_t newinfo = {0};
strcpy((char*)newinfo.ssid, sSmartConfigSSID);
strcpy((char*)newinfo.password,sSmartConfigPassword );
newinfo.ssid_len = strlen((char*) newinfo.ssid);
memset(newinfo.bssid, '\0', 6);
newinfo.allow_router_switch = true;
ESP_LOGI(HOMEIOT_TAG, "OnMeshNoParent: Setting mesh router info to ssid[%s] password[%s] len[%d]", newinfo.ssid, newinfo.password, newinfo.ssid_len);
esp_err_t err = esp_mesh_set_router(&newinfo);
ESP_LOGI(HOMEIOT_TAG, "Finished set router err [%d = %s]", err, esp_err_to_name(err));
bSmartConfigDone = true;
void DoSmartConfig (void *parm)
EventBits_t uxBits;
ESP_LOGI(HOMEIOT_TAG, "DoSmartConfig: Starting Smart Config");
ESP_ERROR_CHECK( esp_smartconfig_set_type(SC_TYPE_ESPTOUCH) );
ESP_ERROR_CHECK( esp_smartconfig_start(cbOnSmartConfigEvent, 1) );
ESP_LOGI(HOMEIOT_TAG, "DoSmartConfig: Smart Config Started");
while (1)
uxBits = xEventGroupWaitBits(s_wifi_event_group, ESPTOUCH_DONE_BIT, true, false, portMAX_DELAY);
if(uxBits & ESPTOUCH_DONE_BIT)
ESP_LOGI(HOMEIOT_TAG, "DoSmartConfig: Stopping Smart Config");
esp_smartconfig_stop();
// Notify task which initiated the smart config process that we have got the data
xEventGroupSetBits(s_wifi_event_group, SMARTCONFIG_GOT_DATA_BIT);
vTaskDelete(NULL);
ESP_LOGI(HOMEIOT_TAG, "DoSmartConfig: Smart Config task deleted");
static void cbOnSmartConfigEvent(smartconfig_status_t status, void *pdata)
switch (status) {
case SC_STATUS_WAIT:
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: SC_STATUS_WAIT");
break;
case SC_STATUS_FIND_CHANNEL:
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: SC_STATUS_FINDING_CHANNEL");
break;
case SC_STATUS_GETTING_SSID_PSWD:
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: SC_STATUS_GETTING_SSID_PSWD");
break;
case SC_STATUS_LINK:
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: SC_STATUS_LINK");
wifi_config_t *wifi_config = pdata;
// Store the SSID and Password in the global variables to pass to the Mesh thread
strcpy(sSmartConfigSSID, (char*)wifi_config->sta.ssid);
strcpy(sSmartConfigPassword,(char*)wifi_config->sta.password );
// Notify function that created the Smart config task that we are done
// Switching router config is done in the mesh task as doing it here fails.
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: Notifying Smart Config has data");
xEventGroupSetBits(s_wifi_event_group, ESPTOUCH_DONE_BIT);
break;
case SC_STATUS_LINK_OVER: // This will never be executed as connection done in mesh thread after this is killed.
ESP_LOGI(HOMEIOT_TAG, "cbOnSmartConfigEvent: SC_STATUS_LINK_OVER");
break;
default:
break;
Hi lee,
Mesh event cb is belong to mesh_nwk_task, it should be non-block .
I'll try to reproduce your issue.
Thanks. Is the smart config on the WiFi task by any chance? I wonder if this issue is related to my issue with espnow and mesh interoperability. Maybe the mesh task and the WiFi tasks don't interoperate correctly?
Our colleagues will provide an example to use smart config later...
Any update on using smart config with wifi mesh? Are there APIs that allow for that or do we still need to implement work arounds?
Users browsing this forum: No registered users and 16 guests
