LR mode in mesh
_erik_
LR mode in mesh
Postby _erik_ » Tue Apr 09, 2019 7:52 am
Is it possible to use the LR (Long Range) mode in a mesh when it is routerless?
What are the optimal RSSI configurations for the mesh when using LR...
Best Regards,
_erik_
ESP_yudong
Re: LR mode in mesh
Postby ESP_yudong » Mon Apr 15, 2019 1:43 pm
I think LR mode can be used in ESP-MESH.
The rssi configuration depends on whether the nodes can connect or communicate smoothly. If you use LR, the rsssi should be able to set lower.
