"Mwifi also supports the way to fix the root node" What does this mean?
Posted: Sun Jul 14, 2019 6:22 am
by eos1d3
In Mwifi API, https://docs.espressif.com/projects/esp ... index.html
Mwifi also supports the way to fix the root node. In this case, the nodes in the entire ESP-MESH network cannot communicate with the external IP network through wifi.
What does this mean? What is "FIX"?
Re: "Mwifi also supports the way to fix the root node" What does this mean?
Posted: Mon Jul 15, 2019 6:27 am
by ESP_LBB
Hi eos1d3,
It means when the devices is powered on, it can only be root node. As this root don't connect to a router, then the whole network under this root won't be able to communicate with the external IP network.
Posted: Tue Jul 16, 2019 3:48 pm
by eos1d3
So it is "no_router" mode in the examples, right? But I think the wording is confusing.
Thanks!
Posted: Wed Jul 17, 2019 4:22 am
by ESP_LBB
Yes, it works in no_router situation, but even if there is router, this kind of networking still works.
In some special scenario, we may need some devices (audio devices with WROVER module for example) to be root node as it has more powerful computing capacity, to control other nodes(bulbs with ESP32-S0WD chip), then in this system we may need the smart speaker to become the root.
