Internet Access over Mesh network
hetal.panara82
Postby hetal.panara82 » Sun Aug 11, 2019 12:25 pm
Hello Experts,
I am very new to the ESP32 Mesh. However designing following solution using Mesh,
1. Have a wifi router with internet connection over broadband. It allows other devices to connect to internet using wifi
2. Create a Mesh using ESP32 modules as shown in attached diagram
3. The Root node is connected to wifi router and have internet connectivity through router
4. There are multiple nodes in Mesh connected to root node and have internet connection over mesh network.
5. All the mesh nodes should work as access point and allow other devices such as mobile to have internet access. Mobiles should be able to use the internet through Mesh Node seamlessly.
Questions:
1. Is this feasible using ESP32 chipset? Any other chipset suggestion for better performance?
2. Any reference architecture similar to above would help.
I see there are many examples around which supports IOT devices to be connected over mesh but did not see any reference which lets end user mobile access internet through Mesh Node.
Appreciate any pointers/suggestions.
/Hp
it_zzc
Re: Internet Access over Mesh network
Postby it_zzc » Thu Sep 05, 2019 3:27 am
ESP-MESH is a networking solution for iot devices and cannot connect to the Internet via ESP-MESH
sensor_s
Postby sensor_s » Sat Sep 14, 2019 1:53 pm
