Mesh uses HT40, this uses too many channels. Can I used HT20?
hassan789
Postby hassan789 » Tue Aug 27, 2019 6:41 pm
Mesh uses HT40, this uses too many channels, causing issues with existing Wifi infrastructure in large buildings.
Is it possible to force everything to go down to HT20, so less 2.4GHz channels are used?
Thanks :D
ESP_LBB
Re: Mesh uses HT40, this uses too many channels. Can I used HT20?
Postby ESP_LBB » Wed Aug 28, 2019 4:03 am
Hi hassan789,
Please check this link if it helps: https://docs.espressif.com/projects/esp ... fi-ht20-40
hassan789
Postby hassan789 » Thu Aug 29, 2019 3:05 pm
tried both modes, and it did not work.... was this ever tested?
esp_wifi_set_mode(WIFI_MODE_APSTA);
esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20);
esp_wifi_set_mode(WIFI_MODE_STA);
hassan789
Postby hassan789 » Mon Sep 02, 2019 6:46 am
got it to work, doing the following:
        ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
        ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_STA, WIFI_BW_HT20));
        ESP_ERROR_CHECK(esp_wifi_set_bandwidth(ESP_IF_WIFI_AP, WIFI_BW_HT20));
