I am using WiFi mesh application router from ESP MDF. I am using ESP32D0WDQ5 (revision 3) chip. From menuconfig, under "Partition Table", we have selected "Custom partition table CSV". The details of partition.csv is as shown below
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs, data, nvs, 0x9000, 16k
otadata, data, ota, 0xd000, 8k
phy_init, data, phy, 0xf000, 4k
ota_0, app, ota_0, 0x10000, 0x180000
ota_1, app, ota_1, , 0x180000
When i run the application built using above partition table, it gives following error
I (30) boot: ESP-IDF v4.3-dev-771-gc77c4ccf6-dirty 2nd stage bootloader
I (30) boot: compile time 11:48:04
I (31) boot: chip revision: 3
I (34) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (47) boot.esp32: SPI Speed : 40MHz
I (47) boot.esp32: SPI Mode : DIO
I (51) boot.esp32: SPI Flash Size : 4MB
I (55) boot: Enabling RNG early entropy source...
I (61) boot: Partition Table:
I (64) boot: ## Label Usage Type ST Offset Length
I (72) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (79) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (86) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (94) boot: 3 ota_0 OTA app 00 10 00010000 001e0000
I (101) boot: 4 ota_1 OTA app 00 11 001f0000 001e0000
I (109) boot: 5 coredump Unknown data 01 03 003d0000 00010000
I (116) boot: 6 reserved Unknown data 01 fe 003e0000 00020000
I (124) boot: End of partition table
I (128) boot: No factory image, trying OTA 0
I (133) boot_comm: chip revision: 3, min. application chip revision: 0
I (140) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x3bf50 (245584) map
I (243) esp_image: segment 1: paddr=0x0004bf78 vaddr=0x3ffbdb60 size=0x040a0 ( 16544) load
I (250) esp_image: segment 2: paddr=0x00050020 vaddr=0x400d0020 size=0x105e80 (1072768) map
0x400d0020: _stext at ??:?
I (659) esp_image: segment 3: paddr=0x00155ea8 vaddr=0x3ffc1c00 size=0x00f84 ( 3972) load
I (661) esp_image: segment 4: paddr=0x00156e34 vaddr=0x40080000 size=0x00404 ( 1028) load
0x40080000: _WindowOverflow4 at /mnt/shared/esp-mdf_testing/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1730
I (666) esp_image: segment 5: paddr=0x00157240 vaddr=0x40080404 size=0x1c464 (115812) load
I (741) boot: Loaded app from partition at offset 0x10000
Fatal exception (28): LoadProhibited
epc1=0x40080703, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000002c, depc=0x00000000
ets Jul 29 2019 12:21:46
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:7068
load:0x40078000,len:12744
load:0x40080400,len:5088
0x40080400: _init at ??:?
entry 0x400806ac
I am able to run normal WiFi code using above parition table, but this one fails, Can anyone please help me on this?
LoadProhibited error using custom partition table on ESP32D0WDQ5 (revision 3) chip
Users browsing this forum: No registered users and 8 guests
