Question about the MDF light example
XiotSamuel
Postby XiotSamuel » Wed Oct 20, 2021 9:47 am
I am studying the code of the light example for my project but I am quite not understand following.
1. how do the root node relay the required message to the node?
2. what is the purpose for the following code? I found those code in the node_handle_task
         * @brief Processing request commands, generating response data
         * @note  Handling only the body part of http, the header
         *        of http is handled by mlink_httpd
        mlink_handle_data_t handle_data = {
            .req_data    = (char *)data,
            .req_size    = size,
            .req_fromat  = MLINK_HTTPD_FORMAT_JSON,
            .resp_data   = NULL,
            .resp_size   = 0,
            .resp_fromat = MLINK_HTTPD_FORMAT_JSON,
        ret = mlink_handle_request(&handle_data);
        MDF_ERROR_GOTO(ret != MDF_OK, FREE_MEM, "<%s> mlink_handle", mdf_err_to_name(ret));
        if (handle_data.resp_fromat == MLINK_HTTPD_FORMAT_JSON) {
            mlink_json_pack(&handle_data.resp_data, "status_msg", mdf_err_to_name(ret));
            handle_data.resp_size = mlink_json_pack(&handle_data.resp_data, "status_code", -ret);
3. If I need to modify the control message of this example for project development. Which part I should change?
Samuel
XiotSamuel
Re: Question about the MDF light example
Postby XiotSamuel » Thu Oct 21, 2021 6:22 am
Hi. I found the node handle task use the uint8_t as data type. Any reason for that?
    uint8_t *data = NULL;
XiotSamuel
Postby XiotSamuel » Thu Oct 21, 2021 10:57 am
Is there have any way to make it into string and compare it? I found that the compare string cannot work with the uint8.
Users browsing this forum: No registered users and 21 guests
