Sending sensor data across mesh network
imark007
Postby imark007 » Sat Oct 06, 2018 1:26 pm
What would the most robust method be to send sensor data from a leaf node on the mesh to the root node? I was looking into the trigger API to do this but wasn’t clear how to receive the values on the root device from the leaf device. The other option I was considering was using the mdf wifi send and receive commands directly. I am thinking that the mdf trigger API may be more robust with error handling already established.
Any guidance would be much appreciated.
ESP_yudong
Re: Sending sensor data across mesh network
Postby ESP_yudong » Wed Oct 10, 2018 12:52 pm
Either is OK.
MDF APIs are easier to use and IDF APIs are more flexible.
If the packet is to the root, set this parameter 'to' to NULL.
https://docs.espressif.com/projects/esp ... esh_opt_ti
