ESP-MESH testing sample code
cvar12
Postby cvar12 » Tue Mar 12, 2019 9:15 am
I am interested in putting together a WiFi mesh network using ESP-MESH in autonomous mode.
Is there a sample code for testing the mesh performance end-to-end such as latency, throughput etc.?
Since accessing to the mesh from an external IP network is only through the root node connected to a WiFi router, I was thinking about some kind of loopback test where I send packets from a PC to a mesh end node which will return back over the mesh.
Any help on this would be much appreciated.
ESP_LBB
Re: ESP-MESH testing sample code
Postby ESP_LBB » Tue Mar 12, 2019 10:52 am
Hi cvar12,
Maybe you can refer to the example in MDF: https://github.com/espressif/esp-mdf/tr ... r/examples
