trying to send buffer data to node-red through mqtt
Zee_jim
Postby Zee_jim » Tue Dec 11, 2018 9:51 am
hello guys
been stuck on this for a week or so now.
am trying to get an audio sample from esp32 with and electric microphone(not boarded about quality yet).
the problem is i am trying to send the audio file to node-red by can send the full data cause i have a char size of (110) tried every other size above that and didn't get any output.
here's the code below.
#include <PubSubClient.h>
#include <WiFi.h>
#include <WiFiClient.h>
const char* ssid = "";
const char* password = "";
const char* mqttServer = "";
const int mqttPort = 1883;
String str_payload;
WiFiClient espClient;
PubSubClient client(espClient);
void setup()
  Serial.begin(9600);
  WiFi.begin(ssid,password);
  while(WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  client.setServer(mqttServer, mqttPort);
  while(!client.connected()) {
    Serial.println("Connecting to MQTT...");
    if(client.connect("ESP8266Client" )) {
      Serial.println("connected");
    }else{
      Serial.print("failed state ");
      Serial.print(client.state());
      delay(2000);
vibrate();
 my_analog();
void loop()
void vibrate(){
  pinMode(2, OUTPUT);
  digitalWrite(2,HIGH);
  delay(2000);
  digitalWrite(2,LOW);
   my_record();
void my_record()
  for(int y=0;y<11;y++)
    for(int i=0;i<800;i++)
      str_payload += char(analogRead(35)/4);
//       Serial.println(str_payload.length());
  my_print();
void my_analog()
  if(digitalRead(2)==LOW)
    my_record();
void my_print()
  char buf[110];
//  String str_payload = String(str_payload);
  String (str_payload).toCharArray(buf,110);
  Serial.print("publishing");
  client.publish("test/esp8266",buf);
  str_payload="";
// Serial.println(str_topic);
// Serial.println(buf);
 Serial.println("finish");
thanks..
tommeyers
Re: trying to send buffer data to node-red through mqtt
Postby tommeyers » Tue Dec 11, 2018 12:23 pm
It is not clear what the problem is. What did you observe?
For more completer info:
Start MQTT Broker in verbose
Subscribe to all messages (#) with subscribe tool
IT Professional, Maker
Santiago, Dominican Republic
ESP_Me-no-dev
Postby ESP_Me-no-dev » Tue Dec 11, 2018 12:25 pm
Why do you use String to collect byte data? Not all bytes are printable chars. Did you try to ask around in the PubSub repository?
Zee_jim
Postby Zee_jim » Wed Dec 12, 2018 9:53 am
the problem is i cant save my audio buffer size of 1k into a char buffer( i don't know why), and the pubsubclient library wont let me send an audio buffer or string directly to node-red so i read the audio file as a string and then convert to char(what pubsubclient only send) but the char buffer does not give me more than [110] bytes if i give more i don't get any data at node-red but if i give 110 or less i get something (2 seconds audio) which is not enough for my application.
i want to know how (why) the char buff size doesn't get increased.
tommeyers
Postby tommeyers » Sat Dec 15, 2018 11:51 pm
So you are not using an mqtt broker. If so, install and use an mqtt broker.
Users browsing this forum: Applebot and 1 guest
