I bought one chinese board and supposily the original files to download is this website https://hkdoc.readthedocs.io/en/latest/ ... duino.html
But when I try to download baidu not allow me: 服务异常
This is the original repository to the HK-ESP32-CAM-MB board, why this board it s not included in the official espressif repository?
How can I use this board?Somebody can provide me the files or instead can tell me what board from the official espressif repository is compatible?I tried AIThinker and the code is uploaded fine but the board not work well because it s not the same.
Somebody can tell how can i get the firmwares?
Firmware problem with chinese board HK-ESP32-CAM
Re: Firmware problem with chinese board HK-ESP32-CAM
As we (Espressif) don't make the board, there's nothing I can do from the company on. Suggest you contact the people who manufactured the board instead, see if they can give you the SDK using some other method.
Have you managed to get the firmware? I have the same problem
Hi
Im new here.
I got the same problem, did you found a solution?
Regards Jonas
Im new here.
Regards Jonas
I used this website to download the HK-ESP32 CAM (chinese board) files from Baidu:
https://imwcr.cn/api/bdwp/
Baidu links found at:
-- [espressif.rar]
-- https://pan.baidu.com/s/1BXT0BUuBzCrGQT9FAb5qXw
-- PW: 8ita
-- [Arduino HK-ESP32 CAM example project]
-- https://pan.baidu.com/s/1VSRq1r4uuFC9FuJgUIHqwg
-- PW: 7cld
to download the files go to -> https://imwcr.cn/api/bdwp/
1. Field: Baidu link
2. Field: PW
3. Field: Password displayed in the Popup when entering https://imwcr.cn/api/bdwp/
if the generatet downlodlink is not working you need to use aria2 downloader -> https://imwcr.cn/api/bdwp/?help
-- [espressif.rar]
-- PW: 8ita
-- PW: 7cld
2. Field: PW
fabersam wrote: ↑Wed Oct 13, 2021 11:24 pmI used this website to download the HK-ESP32 CAM (chinese board) files from Baidu:
-- [espressif.rar]
-- PW: 8ita
-- PW: 7cld
2. Field: PW
Thank you
Example files are downloadable, but espressif SDK isn't even I tried Motrix, I got error code 22.
Would you please upload the SDK to storage cloud? Thank you in advance.
You can download the files here:
https://mega.nz/folder/pMMhCALK#e74H2nGjrUPEe2ta3iGfzA
Note that if you have already installed esp32 espressif via Arduino Boardmanager, you must uninstall it and then extract espressif.rar into Arduino\hardware folder.
Users browsing this forum: No registered users and 46 guests
