Help with TFTdisplay Driver IC: NT35510 SKU:MRB3973
yhanchristian
Postby yhanchristian » Wed Aug 17, 2022 5:03 pm
Hi, everyone!
I'm using the ESP32-S3-DevKitC-1-N32R8V with a TFT Display SKU:MRB3973 like this model: http://www.lcdwiki.com/3.97inch_16BIT_M ... KU:MRB3973.
I use esp-iot-solution screen component to integrate with NT35510 controller and my code compiles, but the display doesn't work only shows a black SCREEN and doesn't draw a pixel in red color, like my code example to test it.
Follow my code in github to check: https://github.com/YhanChristian/Estudo ... ltzscooter
I've checked the hardware many times and didn't find an error in connections.
Anyone have worked with this display? What can I do to make it's work.
Best Regards,
Yhan Christian
ESP_Minatel
Re: Help with TFTdisplay Driver IC: NT35510 SKU:MRB3973
Postby ESP_Minatel » Thu Sep 08, 2022 9:41 am
Have you tried this i80_controller example?
yhanchristian
Postby yhanchristian » Mon Sep 12, 2022 11:14 pm
Thanks to answer, i'll check and test with this lib controller.
Best Regards,
Yhan Christian
Users browsing this forum: No registered users and 20 guests
