Hello, I am creating a mesh network with wireless pressure sensor which share the data router module and which is connected serially to ESP32 which will be helping me to connect the device with smart phone as well as Azure.
I need to learn about how can I receive the sensor data this sensor through mesh router which is connected serially?
I am new to ESP32 device so some any suggestion to make it work with my router will be much helpful.
Send Wireless Pressure sensor data to Azure using ESP32
Re: Send Wireless Pressure sensor data to Azure using ESP32
Hi.
I am still looking for the same.
Watching some videos in youtube the explanations still quite bad.
By the way i will post my software program for comments.
If you are using esp-mesh functions in esp-idf, I think each node can send data to the root node, then the root node can forward those data to outside server.harry97 wrote: ↑Tue Oct 09, 2018 10:17 amHello, I am creating a mesh network with wireless pressure sensor which share the data router module and which is connected serially to ESP32 which will be helping me to connect the device with smart phone as well as Azure.
Which explanations is 'quite bad' to you? We can find a way to improve.danielfs1987 wrote: ↑Tue Nov 06, 2018 6:02 pmHi.
Hi, I have sorted this thing out by using mentioned below article which will definitely help you out too. They have connected the wireless modem with ESP32 using UART connection protocol. it's worked fine.
https://ncd.io/getting-started-with-mic ... ty-sensor/
Users browsing this forum: No registered users and 55 guests
