我用arduino写了一个测试程序,共有8个进程,让它们单独在一个核心上运行和分布在两个核心上运行,效果为啥是一样的,性能没有改变。单核心运行所有进程每个任务耗时460微秒。所有任务分布到两个核心上还是460微秒。
volatile int item;
volatile long item1;
volatile int itm;
volatile long itm1;
volatile int it;
volatile long it1;
volatile int t;
volatile long t1;
volatile int z;
volatile long z1;
volatile int x;
volatile long x1;
volatile int c;
volatile long c1;
volatile int g;
volatile long g1;
extern "C"
uint8_t temprature_sens_read();
void task_1( void * pvParameters ){
for(;;){
digitalWrite(2,HIGH);
delay(1000);
digitalWrite(2,LOW);
delay(1000);
item = micros();
for (int i = 1; i <= 10000; i = i + (1)) {
item1 = item1 + 1;
item = micros() - item;
Serial.println(String("p1:") + String(item));
Serial.println(item1);
Serial.println((temprature_sens_read() - 32) / 1.8);
if (item1 > 9000000000) {
item1 = 1;
vTaskDelay(1);
void task_2( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
itm = micros();
itm1 = itm1 + 2;
itm = micros() - itm;
Serial.println(String("p2:") + String(itm));
Serial.println(itm1);
if (itm1 > 9000000000) {
itm1 = 1;
vTaskDelay(1);
void task_3( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
it = micros();
it1 = it1 + 3;
it = micros() - it;
Serial.println(String("p3:") + String(it));
Serial.println(it1);
if (it1 > 9000000000) {
it1 = 1;
vTaskDelay(1);
void task_4( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
t = micros();
t1 = t1 + 4;
t = micros() - t;
Serial.println(String("p4:") + String(t));
Serial.println(t1);
if (t1 > 9000000000) {
t1 = 1;
vTaskDelay(1);
void task_5( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
z = micros();
z1 = z1 + 5;
z = micros() - z;
Serial.println(String("p5:") + String(z));
Serial.println(z1);
if (z1 > 9000000000) {
z1 = 1;
vTaskDelay(1);
void task_6( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
x = micros();
x1 = x1 + 6;
x = micros() - x;
Serial.println(String("p6:") + String(x));
Serial.println(x1);
if (x1 > 9000000000) {
x1 = 1;
vTaskDelay(1);
void task_7( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
c = micros();
c1 = c1 + 6;
c = micros() - c;
Serial.println(String("p7:") + String(c));
Serial.println(c1);
if (c1 > 9000000000) {
c1 = 1;
vTaskDelay(1);
void task_8( void * pvParameters ){
for(;;){
delay(1000);
delay(1000);
g = micros();
g1 = g1 + 6;
g = micros() - g;
Serial.println(String("p8:") + String(g));
Serial.println(g1);
if (g1 > 9000000000) {
g1 = 1;
vTaskDelay(1);
void setup(){
item = 0;
item1 = 1;
pinMode(2, OUTPUT);
Serial.begin(9600);
xTaskCreatePinnedToCore(task_1,"task_1",4096,NULL,2,NULL,0);
itm = 0;
itm1 = 1;
xTaskCreatePinnedToCore(task_2,"task_2",4096,NULL,2,NULL,0);
it = 0;
it1 = 1;
xTaskCreatePinnedToCore(task_3,"task_3",4096,NULL,2,NULL,0);
t = 0;
t1 = 1;
xTaskCreatePinnedToCore(task_4,"task_4",4096,NULL,2,NULL,0);
z = 0;
z1 = 1;
xTaskCreatePinnedToCore(task_5,"task_5",4096,NULL,2,NULL,1);
x = 0;
x1 = 1;
xTaskCreatePinnedToCore(task_6,"task_6",4096,NULL,2,NULL,1);
c = 0;
c1 = 1;
xTaskCreatePinnedToCore(task_7,"task_7",4096,NULL,2,NULL,1);
g = 0;
g1 = 1;
xTaskCreatePinnedToCore(task_8,"task_8",4096,NULL,2,NULL,1);
void loop(){
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
vTaskDelay(1);
关于esp32双核调用及性能问题
关于esp32双核调用及性能问题
- esp多任务测试.txt
- (4.76 KiB) Downloaded 362 times
Re: 关于esp32双核调用及性能问题
你可以认为 2 个核还是各跑各的任务,每个任务还是需要原来一样多的时间。并不是说一个任务,因为有 2 个核了,就会快。但现在有 2 个核,你所有的任务跑完,耗费的时间,会比 1 个核少。
Users browsing this forum: No registered users and 61 guests
