esp32c3 qspi能否驱动屏幕 是否有相关历程
qixin123
Postby qixin123 » Wed Jul 28, 2021 5:18 am
esp32c3 qspi驱动屏幕是否可以 有相关历程嘛
ESP_Gargamel
Re: esp32c3 qspi能否驱动屏幕 是否有相关历程
Postby ESP_Gargamel » Wed Jul 28, 2021 7:09 am
暂时可能没有,你可以参考 https://github.com/espressif/esp-idf/tr ... /lcd/tjpgd 修改。另外你使用的是那款屏?
qixin123
Postby qixin123 » Wed Jul 28, 2021 3:01 pm
用的是 ST77903 QSPI接口的屏幕
ESP_Gargamel
Postby ESP_Gargamel » Thu Jul 29, 2021 2:10 am
我们没有试过这款,不过底层驱动是支持 qspi 的,需要你自己调试一下。或者是否有此款 lcd 的采购链接或途径,我们可以适配一下。
qixin123
Postby qixin123 » Sat Jul 31, 2021 3:51 am
看下您是否方便 您加我下 我把资料发您。
qixin123
Postby qixin123 » Sat Jul 31, 2021 3:52 am
18246767335
modi21jin
Postby modi21jin » Sun Feb 19, 2023 7:42 am
【淘宝】https://m.tb.cn/h.ULcYThv?tk=GhagdSp9msx CZ3457 「1.65寸触摸屏全贴合总成件400*400QSPI编码器家电旋钮全圆显示屏」
点击链接直接打开 或者 淘宝搜索直接打开
modi21jin
Postby modi21jin » Fri May 26, 2023 7:03 am
It is not recommended to use ST77903 for ESP32C3 because it has no GRAM.
Hesitant screen does not have GRAM, so ESP32C3 needs to manage screen refresh (freertos queue) by itself and needs to open up a buffer 400*400*8*2=1.23MB in SRAM. Obviously, SRAM is not enough and there is no PSRAM, so ESP32C3 cannot click ST77903.
If you want to order ST77903, choose ESP32•ESP32S2•ESP32S3 because they all have QSPI interface and PSRAM
ESP32C3 can try to use a QSPI screen with RAM, such as SPD2010 or SPD2012
If there is anything wrong, please let me know.
【淘宝】https://m.tb.cn/h.UwnjUjU?tk=wEODdLSA0mS CZ0001 「1.46寸圆形液晶显示屏412*412小家电开关旋钮屏LCD彩屏TFT液晶屏」
【淘宝】https://m.tb.cn/h.UEuLnis?tk=hyVvdL700fO CZ3457 「鱼鹰光电® 1.72寸tft 356*400COG液晶模组 QSPI接口TFT显示模块」
mainy4210
Postby mainy4210 » Mon Jul 17, 2023 2:51 am
想请问下您是否驱动成功了?我也是这个型号的屏幕芯片,想要一份代码参考一下。邮箱:1443176576@qq.com
Users browsing this forum: No registered users and 108 guests
