idf安装错误????
zhn1021256354
idf安装错误????
Postby zhn1021256354 » Sun Oct 17, 2021 1:33 am
2021-10-17 09:05:54.012 Log opened. (Time zone: UTC+08:00)
2021-10-17 09:05:54.012 Setup version: Inno Setup version 6.2.0
2021-10-17 09:05:54.012 Original Setup EXE: E:\Users\10212\.espressif\esp-idf-tools-setup-online-2.11.exe
2021-10-17 09:05:54.012 Setup command line: /SL5="$560918,2460577,831488,E:\Users\10212\.espressif\esp-idf-tools-setup-online-2.11.exe"
2021-10-17 09:05:54.012 Windows version: 10.0.19042 (NT platform: Yes)
2021-10-17 09:05:54.013 64-bit Windows: Yes
2021-10-17 09:05:54.013 Processor architecture: x64
2021-10-17 09:05:54.013 User privileges: None
2021-10-17 09:05:54.019 Administrative install mode: No
2021-10-17 09:05:54.019 Install mode root key: HKEY_CURRENT_USER
2021-10-17 09:05:54.019 64-bit install mode: Yes
2021-10-17 09:05:56.003 Created temporary directory: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp
2021-10-17 09:05:56.009 -- DLL function import --
2021-10-17 09:05:56.009 Function name: idpAddFile
2021-10-17 09:05:56.009 DLL name: files:idp.dll
2021-10-17 09:05:56.009 Extracting temporary file: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.019 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.019 Importing the DLL function.
2021-10-17 09:05:56.028 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.028 -- DLL function import --
2021-10-17 09:05:56.028 Function name: idpAddFileComp
2021-10-17 09:05:56.028 DLL name: files:idp.dll
2021-10-17 09:05:56.028 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.028 Importing the DLL function.
2021-10-17 09:05:56.029 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.029 -- DLL function import --
2021-10-17 09:05:56.029 Function name: idpAddMirror
2021-10-17 09:05:56.029 DLL name: files:idp.dll
2021-10-17 09:05:56.029 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.029 Importing the DLL function.
2021-10-17 09:05:56.029 Function name: idpAddFtpDir
2021-10-17 09:05:56.030 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.030 Importing the DLL function.
2021-10-17 09:05:56.030 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.030 -- DLL function import --
2021-10-17 09:05:56.030 Function name: idpAddFtpDirComp
2021-10-17 09:05:56.030 DLL name: files:idp.dll
2021-10-17 09:05:56.030 Function name: idpClearFiles
2021-10-17 09:05:56.031 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.031 Importing the DLL function.
2021-10-17 09:05:56.031 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.031 -- DLL function import --
2021-10-17 09:05:56.031 Function name: idpFilesCount
2021-10-17 09:05:56.031 DLL name: files:idp.dll
2021-10-17 09:05:56.032 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.032 Importing the DLL function.
2021-10-17 09:05:56.032 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.032 -- DLL function import --
2021-10-17 09:05:56.032 Function name: idpFtpDirsCount
2021-10-17 09:05:56.032 DLL name: files:idp.dll
2021-10-17 09:05:56.033 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.033 -- DLL function import --
2021-10-17 09:05:56.033 Function name: idpFileDownloaded
2021-10-17 09:05:56.033 DLL name: files:idp.dll
2021-10-17 09:05:56.034 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.034 Importing the DLL function.
2021-10-17 09:05:56.034 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.034 -- DLL function import --
2021-10-17 09:05:56.034 Function name: idpFilesDownloaded
2021-10-17 09:05:56.034 DLL name: files:idp.dll
2021-10-17 09:05:56.034 Function name: idpDownloadFile
2021-10-17 09:05:56.035 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.035 Importing the DLL function.
2021-10-17 09:05:56.035 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.035 -- DLL function import --
2021-10-17 09:05:56.035 Function name: idpDownloadFiles
2021-10-17 09:05:56.035 DLL name: files:idp.dll
2021-10-17 09:05:56.035 Function name: idpDownloadFilesComp
2021-10-17 09:05:56.036 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.036 -- DLL function import --
2021-10-17 09:05:56.036 Function name: idpDownloadFilesCompUi
2021-10-17 09:05:56.036 DLL name: files:idp.dll
2021-10-17 09:05:56.036 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.036 Importing the DLL function.
2021-10-17 09:05:56.036 Function name: idpStartDownload
2021-10-17 09:05:56.036 Function name: idpStopDownload
2021-10-17 09:05:56.037 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.037 Importing the DLL function.
2021-10-17 09:05:56.037 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.037 -- DLL function import --
2021-10-17 09:05:56.037 Function name: idpSetLogin
2021-10-17 09:05:56.037 DLL name: files:idp.dll
2021-10-17 09:05:56.037 Function name: idpSetProxyMode
2021-10-17 09:05:56.038 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.038 -- DLL function import --
2021-10-17 09:05:56.038 Function name: idpSetProxyName
2021-10-17 09:05:56.038 DLL name: files:idp.dll
2021-10-17 09:05:56.038 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.038 Importing the DLL function.
2021-10-17 09:05:56.038 Function name: idpSetProxyLogin
2021-10-17 09:05:56.039 Function name: idpConnectControl
2021-10-17 09:05:56.039 DLL name: files:idp.dll
2021-10-17 09:05:56.039 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.039 Importing the DLL function.
2021-10-17 09:05:56.039 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.039 -- DLL function import --
2021-10-17 09:05:56.039 Function name: idpAddMessage
2021-10-17 09:05:56.039 Function name: idpSetInternalOption
2021-10-17 09:05:56.040 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.040 Importing the DLL function.
2021-10-17 09:05:56.040 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.040 -- DLL function import --
2021-10-17 09:05:56.040 Function name: idpSetDetailedMode
2021-10-17 09:05:56.040 DLL name: files:idp.dll
2021-10-17 09:05:56.040 Function name: idpSetComponents
2021-10-17 09:05:56.041 Function name: idpReportError
2021-10-17 09:05:56.041 DLL name: files:idp.dll
2021-10-17 09:05:56.041 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.041 Importing the DLL function.
2021-10-17 09:05:56.041 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.041 -- DLL function import --
2021-10-17 09:05:56.041 Function name: idpTrace
2021-10-17 09:05:56.041 Function name: idpAddFileSize
2021-10-17 09:05:56.042 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.042 Importing the DLL function.
2021-10-17 09:05:56.042 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.042 -- DLL function import --
2021-10-17 09:05:56.042 Function name: idpAddFileSize
2021-10-17 09:05:56.042 DLL name: files:idp.dll
2021-10-17 09:05:56.042 Function name: idpGetFileSize
2021-10-17 09:05:56.043 -- DLL function import --
2021-10-17 09:05:56.043 Function name: idpGetFilesSize
2021-10-17 09:05:56.043 DLL name: files:idp.dll
2021-10-17 09:05:56.043 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idp.dll
2021-10-17 09:05:56.043 Importing the DLL function.
2021-10-17 09:05:56.043 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.043 Function name: proc_start
2021-10-17 09:05:56.043 DLL name: files:cmdlinerunner.dll
2021-10-17 09:05:56.043 Extracting temporary file: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\cmdlinerunner.dll
2021-10-17 09:05:56.050 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\cmdlinerunner.dll
2021-10-17 09:05:56.051 Importing the DLL function.
2021-10-17 09:05:56.057 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.057 -- DLL function import --
2021-10-17 09:05:56.057 Function name: proc_get_exit_code
2021-10-17 09:05:56.057 DLL name: files:cmdlinerunner.dll
2021-10-17 09:05:56.057 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\cmdlinerunner.dll
2021-10-17 09:05:56.057 Importing the DLL function.
2021-10-17 09:05:56.057 Function name: proc_get_output
2021-10-17 09:05:56.058 Dest DLL name: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\cmdlinerunner.dll
2021-10-17 09:05:56.058 Importing the DLL function.
2021-10-17 09:05:56.058 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.058 -- DLL function import --
2021-10-17 09:05:56.058 Function name: proc_end
2021-10-17 09:05:56.058 DLL name: files:cmdlinerunner.dll
2021-10-17 09:05:56.058 Function name: SetEnvironmentVariableW
2021-10-17 09:05:56.058 DLL name: kernel32.dll
2021-10-17 09:05:56.058 Dest DLL name: kernel32.dll
2021-10-17 09:05:56.059 -- DLL function import --
2021-10-17 09:05:56.059 Function name: PeekMessageW
2021-10-17 09:05:56.059 DLL name: user32.dll
2021-10-17 09:05:56.059 Dest DLL name: user32.dll
2021-10-17 09:05:56.059 Importing the DLL function.
2021-10-17 09:05:56.059 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.059 Function name: TranslateMessage
2021-10-17 09:05:56.059 Function name: DispatchMessageW
2021-10-17 09:05:56.060 Importing the DLL function.
2021-10-17 09:05:56.060 Successfully imported the DLL function. Delay loaded? No
2021-10-17 09:05:56.311 Configuration /CONFIG=
2021-10-17 09:05:56.311 Configuration /GITCLEAN=yes
2021-10-17 09:05:56.312 Configuration /GITRECURSIVE=yes
2021-10-17 09:05:56.312 Configuration /GITRESET=yes
2021-10-17 09:05:56.312 Configuration /GITREPO=https://github.com/espressif/esp-idf.git
2021-10-17 09:05:56.312 Configuration /IDFDIR=
2021-10-17 09:05:56.313 Configuration /IDFUSEEXISTING=no
2021-10-17 09:05:56.313 Configuration /IDFVERSION=
2021-10-17 09:05:56.313 Configuration /IDFVERSIONSURL=https://dl.espressif.com/dl/esp-idf/idf_versions.txt
2021-10-17 09:05:56.313 Configuration /OFFLINE=no
2021-10-17 09:05:56.314 Configuration /PYTHONNOUSERSITE=yes
2021-10-17 09:05:56.314 Configuration /PYTHONWHEELSURL=https://dl.espressif.com/pypi
2021-10-17 09:05:56.314 Configuration /PYTHONWHEELSVERSION=3.8-2021-08-10
2021-10-17 09:05:56.314 Configuration /SKIPSYSTEMCHECK=no
2021-10-17 09:05:56.315 Configuration /USEEMBEDDEDGIT=yes
2021-10-17 09:05:56.315 Configuration /USEEMBEDDEDPYTHON=yes
2021-10-17 09:05:56.321 Extracting temporary file: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe
2021-10-17 09:05:56.465 Adding Python version=3.8.7 name=Use Python 3.8.7 Embedded (Recommended) executable=tools\idf-python\3.8.7\python.exe
2021-10-17 09:05:56.502 Found link in "For more infojects/esp-idf/en/latest/versions.html": "https://docs.espressif.com/projects/esp ... sions.html"
2021-10-17 09:06:00.060 * Starting system check ...
2021-10-17 09:06:00.065 * Checking "Long Paths Enabled" in Windows registry
2021-10-17 09:06:00.068 [OK]
2021-10-17 09:06:00.070 * Checking certificates
2021-10-17 09:06:00.072 $ C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe certificate verify --url https://dl.espressif.com/dl/?system_che ... 0.00.19042
2021-10-17 09:06:00.931 $ C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe certificate verify --url https://github.com/espressif
2021-10-17 09:06:20.588 thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: reqwest::Error { kind: Request, url: Url { scheme: "https", cannot_be_a_base: false, username: "", password: None, host: Some(Domain("github.com")), port: None, path: "/espressif", query: None, fragment: None }, source: hyper::Error(Connect, Os { code: 10054, kind: ConnectionReset, message: "杩滅▼涓绘満寮鸿揩鍏抽棴浜嗕竴涓幇鏈夌殑杩炴帴銆? }) }', src\certificate.rs:16:43
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: Any { .. }', src\certificate.rs:18:18
2021-10-17 09:06:20.810 [WARN]
2021-10-17 09:06:20.813 Unable to load data from server dl.espressif.com.
2021-10-17 09:06:20.815 Executing: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe antivirus get --property displayName
2021-10-17 09:06:20.903 Result: Windows Defender, Lenovo Anti-Virus powered by Huorong Security
2021-10-17 09:06:20.903 Executing: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe antivirus get --property displayName
2021-10-17 09:06:20.980 Result: Windows Defender, Lenovo Anti-Virus powered by Huorong Security
2021-10-17 09:06:20.980 * Detected antivirus: Windows Defender, Lenovo Anti-Virus powered by Huorong Security
2021-10-17 09:06:20.983 * Check complete.
2021-10-17 09:06:37.188 ApplyPythonConfigurationByIndex index=0
2021-10-17 09:06:37.188 ApplyPythonConfigurationByIndex: PythonPath=tools\idf-python\3.8.7\ PythonExecutablePath=tools\idf-python\3.8.7\python.exe
2021-10-17 09:06:37.197 ApplyPythonConfigurationByIndex index=0
2021-10-17 09:06:37.197 ApplyPythonConfigurationByIndex: PythonPath=tools\idf-python\3.8.7\ PythonExecutablePath=tools\idf-python\3.8.7\python.exe
2021-10-17 09:06:37.199 OnIDFPagePrepare
2021-10-17 09:06:39.403 OnIDFSelectionChange index=1
2021-10-17 09:06:44.965 OnIDFSelectionChange index=0
2021-10-17 09:06:46.173 OnIDFPageValidate index=0
2021-10-17 09:06:46.183 OnIDFDownloadPagePrepare
2021-10-17 09:06:46.604 Downloaded https://dl.espressif.com/dl/esp-idf/idf_versions.txt to C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf_versions.txt
2021-10-17 09:06:46.604 Versions count: 11
2021-10-17 09:06:46.605 Version 0: v4.3.1
2021-10-17 09:06:46.606 Version 1: v4.2.2
2021-10-17 09:06:46.606 Version 2: v4.1.2
2021-10-17 09:06:46.607 Version 3: v4.0.3
2021-10-17 09:06:46.608 Version 4: v3.3.5
2021-10-17 09:06:46.608 Version 5: release/v4.3
2021-10-17 09:06:46.611 Version 6: release/v4.2
2021-10-17 09:06:46.614 Version 7: release/v4.1
2021-10-17 09:06:46.637 Version 8: release/v4.0
2021-10-17 09:06:46.639 Version 9: release/v3.3
2021-10-17 09:06:46.640 Version 10: master
2021-10-17 09:06:48.017 OnIDFDownloadSelectionChange index=5
2021-10-17 09:07:01.077 OnIDFDownloadSelectionChange index=0
2021-10-17 09:07:23.094 OnIDFDownloadPageValidate index=0
2021-10-17 09:07:36.058 Checking location of ToolsDir E:\Users\10212\esp32\.espressif is not a subdirectory of E:\Users\10212\esp32\esp-idf\
2021-10-17 09:07:44.386 Summary message:
Using Python 3.8.7:
Using Embedded Git :
E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe
Will install ESP-IDF v4.3.1 into:
IDF tools directory (IDF_TOOLS_PATH):
2021-10-17 09:07:52.966 Done, exit code=0
2021-10-17 09:07:52.966 --------
2021-10-17 09:07:52.966 Running command: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe driver install --ftdi --silabs --espressif
Downloading https://www.silabs.com/documents/public ... Driver.zip to cp210x.zi
Downloading https://www.ftdichip.com/Drivers/CDM/CD ... tified.zip to ftdi.zi
Downloading https://dl.espressif.com/dl/idf-driver/ ... -07-15.zip to idf-driver-esp32-usb-jtag-2021-07-15.zi
Requesting elevation of privileges for: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\idf-env.exe driver install --ftdi --silabs --espressif --no-download
Exit code: 0x2
2021-10-17 09:07:53.000 PythonExecutablePathUpdateAfterInstall: PythonPath=E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\ PythonExecutablePath=E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe
2021-10-17 09:07:53.000 Checking existence of: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe
2021-10-17 09:07:53.000 Checking download cache for: E:\Users\10212\esp32\.espressif\dist\idf-python-3.8.7-embed-win64.zip
2021-10-17 09:07:53.000 Scheduling download of https://dl.espressif.com/dl/idf-python/ ... -win64.zip to E:\Users\10212\esp32\.espressif\dist\idf-python-3.8.7-embed-win64.zip
2021-10-17 09:07:53.000 Checking existence of: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe
2021-10-17 09:07:53.000 Checking download cache for: E:\Users\10212\esp32\.espressif\dist\idf-git-2.30.1-win64.zip
2021-10-17 09:07:53.000 Scheduling download of https://dl.espressif.com/dl/idf-git/idf ... -win64.zip to E:\Users\10212\esp32\.espressif\dist\idf-git-2.30.1-win64.zip
2021-10-17 09:07:53.000 Checking existence of: E:\Users\10212\esp32\.espressif\tools\idf-eclipse\2021-09\eclipse.exe
2021-10-17 09:07:53.001 Checking download cache for: E:\Users\10212\esp32\.espressif\dist\idf-eclipse-2021-09-win64.zip
2021-10-17 09:07:53.001 Scheduling download of https://dl.espressif.com/dl/idf-eclipse ... -win64.zip to E:\Users\10212\esp32\.espressif\dist\idf-eclipse-2021-09-win64.zip
2021-10-17 09:07:53.001 GetIDFZIPFileVersion(v4.3.1)=v4.3.1
2021-10-17 09:07:53.001 IDFZIPFileVersion: v4.3.1
2021-10-17 09:07:53.001 IDFZIPFileName: E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip exists
2021-10-17 09:07:53.001 Adding download: https://github.com/espressif/esp-idf/re ... v4.3.1.zip, mirror: https://dl.espressif.com/github_assets/ ... v4.3.1.zip, destination: E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip
2021-10-17 09:12:22.639 Found 1 files to register with RestartManager.
2021-10-17 09:12:22.639 Calling RestartManager's RmGetList.
2021-10-17 09:12:22.648 RmGetList finished successfully.
2021-10-17 09:12:22.648 RestartManager found no applications using one of our files.
2021-10-17 09:12:22.661 Starting the installation process.
2021-10-17 09:12:22.664 Directory for uninstall files: E:\Users\10212\esp32\.espressif
2021-10-17 09:12:22.665 Creating new uninstall log: E:\Users\10212\esp32\.espressif\unins000.dat
2021-10-17 09:12:22.667 -- File entry --
2021-10-17 09:12:22.667 Dest filename: E:\Users\10212\esp32\.espressif\unins000.exe
2021-10-17 09:12:22.667 Non-default bitness: 32-bit
2021-10-17 09:12:22.669 Time stamp of our file: 2021-10-17 09:05:53.844
2021-10-17 09:12:22.669 Installing the file.
2021-10-17 09:12:22.680 Successfully installed the file.
2021-10-17 09:12:22.681 -- File entry --
2021-10-17 09:12:22.681 Dest filename: E:\Users\10212\esp32\.espressif\idf-env.exe
2021-10-17 09:12:22.681 Time stamp of our file: 2021-09-24 15:15:56.000
2021-10-17 09:12:22.681 Installing the file.
2021-10-17 09:12:22.802 Successfully installed the file.
2021-10-17 09:12:22.802 -- File entry --
2021-10-17 09:12:22.804 Dest filename: E:\Users\10212\esp32\.espressif\idf_cmd_init.bat
2021-10-17 09:12:22.805 Time stamp of our file: 2021-09-24 15:15:44.000
2021-10-17 09:12:22.805 Installing the file.
2021-10-17 09:12:22.807 Successfully installed the file.
2021-10-17 09:12:22.807 -- File entry --
2021-10-17 09:12:22.807 Dest filename: E:\Users\10212\esp32\.espressif\Initialize-Idf.ps1
2021-10-17 09:12:22.807 Time stamp of our file: 2021-09-24 15:15:44.000
2021-10-17 09:12:22.808 Installing the file.
2021-10-17 09:12:22.809 Successfully installed the file.
2021-10-17 09:12:22.810 -- Registry entry --
2021-10-17 09:12:22.810 Key: HKEY_CURRENT_USER\Environment
2021-10-17 09:12:22.810 Value name: IDF_TOOLS_PATH
2021-10-17 09:12:22.810 Creating or opening the key.
2021-10-17 09:12:22.810 Deleting the value.
2021-10-17 09:12:22.810 Creating or setting the value.
2021-10-17 09:12:22.810 Successfully created or set the value.
2021-10-17 09:12:22.811 Saving uninstall information.
2021-10-17 09:12:22.811 Creating new uninstall key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Uninstall\{9E068D99-5C4B-4E5F-96A3-B17CF291E6BD}_is1
2021-10-17 09:12:22.812 Writing uninstall key values.
2021-10-17 09:12:22.813 Detected previous administrative 64-bit install? No
2021-10-17 09:12:22.814 Detected previous administrative 32-bit install? No
2021-10-17 09:12:23.921 Installation process succeeded.
2021-10-17 09:12:23.931 Extracting temporary file: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe
2021-10-17 09:12:23.993 Checking existence of Embedded Python: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe
2021-10-17 09:12:28.840 Done, exit code=0
2021-10-17 09:12:28.840 --------
2021-10-17 09:12:28.840 Running command: "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe" x "-oE:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\" -r -aoa "E:\Users\10212\esp32\.espressif\dist\idf-python-3.8.7-embed-win64.zip"
7-Zip (a) 19.00 (x64) : Copyright (c) 1999-2018 Igor Pavlov : 2019-02-21
Scanning the drive for archives:
1 file, 20086226 bytes (20 MiB)
Extracting archive: E:\Users\10212\esp32\.espressif\dist\idf-python-3.8.7-embed-win64.zip
Path = E:\Users\10212\esp32\.espressif\dist\idf-python-3.8.7-embed-win64.zip
Type = zip
Physical Size = 20086226
Everything is Ok
Folders: 4
Files: 2046
Compressed: 20086226
2021-10-17 09:12:28.841 --------
2021-10-17 09:12:28.851 Checking existence of Embedded Git: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe
2021-10-17 09:12:31.247 Done, exit code=0
2021-10-17 09:12:31.247 --------
2021-10-17 09:12:31.247 Running command: "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe" x "-oE:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\" -r -aoa "E:\Users\10212\esp32\.espressif\dist\idf-git-2.30.1-win64.zip"
1 file, 27870557 bytes (27 MiB)
Extracting archive: E:\Users\10212\esp32\.espressif\dist\idf-git-2.30.1-win64.zip
Path = E:\Users\10212\esp32\.espressif\dist\idf-git-2.30.1-win64.zip
Type = zip
Physical Size = 27870557
Everything is Ok
Folders: 87
Files: 549
Compressed: 27870557
2021-10-17 09:12:31.249 --------
2021-10-17 09:12:31.262 Checking existence of: E:\Users\10212\esp32\.espressif\tools\idf-eclipse\2021-09\eclipse.exe
2021-10-17 09:12:50.008 Done, exit code=0
2021-10-17 09:12:50.008 --------
2021-10-17 09:12:50.009 Running command: "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe" x "-oE:\Users\10212\esp32\.espressif\tools\idf-eclipse\2021-09\" -r -aoa "E:\Users\10212\esp32\.espressif\dist\idf-eclipse-2021-09-win64.zip"
1 file, 431084107 bytes (412 MiB)
Extracting archive: E:\Users\10212\esp32\.espressif\dist\idf-eclipse-2021-09-win64.zip
Path = E:\Users\10212\esp32\.espressif\dist\idf-eclipse-2021-09-win64.zip
Type = zip
Physical Size = 431084107
Everything is Ok
Folders: 816
Files: 4375
Compressed: 431084107
2021-10-17 09:12:50.009 --------
2021-10-17 09:12:50.023 Setting PATH for this process: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\;E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;D:\Program Files (x86)\Python37-32\Scripts\;D:\Program Files (x86)\Python37-32\;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;D:\Program Files\nodejs\;C:\Program Files\Git\cmd;E:\BaiduNetdiskDownload\env_released_1.1.1\env\tools\qemu\qemu32;C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\;C:\Program Files (x86)\Nordic Semiconductor\nrf5x\nrf\;C:\Python27;C:\Python27\Scripts;E:\RTT\cmder_mini;C:\Program Files\dotnet\;D:\Users\10212\AppData\Local\Programs\Microsoft VS Code;E:\Program Files\doxygen\bin;C:\Program Files\doxygen\bin;C:\Program Files (x86)\Git\cmd;C:\Users\10212\.cargo\bin;C:\Users\10212\AppData\Local\Microsoft\WindowsApps;C:\Users\10212\AppData\Roaming\npm;D:\Users\10212\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\10212\AppData\Local\BypassRuntm;C:\Users\10212\AppData\Local\Microsoft\WindowsApps;
2021-10-17 09:12:50.023 PYTHONNOUSERSITE=True
2021-10-17 09:12:50.023 PYTHONPATH=
2021-10-17 09:12:50.024 PYTHONHOME=
2021-10-17 09:12:50.024 Extracting ESP-IDF reference repository: "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe" x "-oC:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp" -r -aoa "E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip"
2021-10-17 09:12:50.024 Reference repository path: C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\esp-idf-v4.3.1
2021-10-17 09:13:55.854 Done, exit code=0
2021-10-17 09:13:55.854 --------
2021-10-17 09:13:55.854 Running command: "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\7za.exe" x "-oC:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp" -r -aoa "E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip"
1 file, 686827226 bytes (656 MiB)
Extracting archive: E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip
Path = E:\Users\10212\esp32\.espressif\releases\esp-idf-v4.3.1.zip
Type = zip
Physical Size = 686827226
Everything is Ok
Folders: 3695
Files: 16849
Compressed: 686827226
2021-10-17 09:13:55.855 --------
2021-10-17 09:13:55.866 Copying C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\esp-idf-v4.3.1 to E:\Users\10212\esp32\esp-idf
2021-10-17 09:15:19.351 Done, exit code=0
2021-10-17 09:15:19.351 --------
2021-10-17 09:15:19.351 Running command: cmd.exe /c ""xcopy" /s /e /i /h /q "C:\Users\10212\AppData\Local\Temp\is-CBL3V.tmp\esp-idf-v4.3.1" "E:\Users\10212\esp32\esp-idf""
复制了 16849 个文件
2021-10-17 09:15:19.364 Setting core.fileMode on repository: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf config --local core.fileMode false
2021-10-17 09:15:20.245 Done, exit code=0
2021-10-17 09:15:20.245 --------
2021-10-17 09:15:20.245 Running command: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf config --local core.fileMode false
2021-10-17 09:15:20.262 Setting core.fileMode on repository for submodules: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf config --local core.fileMode false
2021-10-17 09:15:26.007 Done, exit code=0
2021-10-17 09:15:26.007 --------
2021-10-17 09:15:26.007 Running command: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf submodule foreach --recursive git config --local core.fileMode false
Entering 'components/asio/asio
Entering 'components/bootloader/subproject/components/micro-ecc/micro-ecc
Entering 'components/bt/controller/lib_esp32
Entering 'components/bt/controller/lib_esp32c3_family
Entering 'components/bt/host/nimble/nimble
Entering 'components/cbor/tinycbor
Entering 'components/cmock/CMock
Entering 'components/cmock/CMock/vendor/c_exception
Entering 'components/cmock/CMock/vendor/unity
Entering 'components/coap/libcoap
Entering 'components/coap/libcoap/ext/tinydtls
Entering 'components/esp_wifi/lib
Entering 'components/esptool_py/esptool
Entering 'components/expat/expat
Entering 'components/json/cJSON
Entering 'components/libsodium/libsodium
Entering 'components/lwip/lwip
Entering 'components/mbedtls/mbedtls
Entering 'components/mqtt/esp-mqtt
Entering 'components/nghttp/nghttp2
Entering 'components/nghttp/nghttp2/third-party/mruby
Entering 'components/nghttp/nghttp2/third-party/neverbleed
Entering 'components/protobuf-c/protobuf-c
Entering 'components/spiffs/spiffs
Entering 'components/tinyusb/tinyusb
Entering 'components/unity/unity
Entering 'examples/build_system/cmake/import_lib/main/lib/tinyxml2
Entering 'examples/peripherals/secure_element/atecc608_ecdsa/components/esp-cryptoauthlib
2021-10-17 09:15:26.011 --------
2021-10-17 09:15:26.040 Resetting the repository: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf reset --hard
2021-10-17 09:15:41.313 Done, exit code=0
2021-10-17 09:15:41.313 --------
2021-10-17 09:15:41.313 Running command: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf reset --hard
Updating files: 100% (8287/8287), done
HEAD is now at 2e74914051 versions: Update version to 4.3.
2021-10-17 09:15:41.326 Resetting the submodules: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf reset --hard
2021-10-17 09:16:12.072 Done, exit code=0
2021-10-17 09:16:12.072 --------
2021-10-17 09:16:12.072 Running command: E:\Users\10212\esp32\.espressif\tools\idf-git\2.30.1\cmd\git.exe -C E:\Users\10212\esp32\esp-idf submodule foreach git reset --hard
Updating files: 100% (1069/1069), done
HEAD is now at f31694c9 ESP Platform SSL support for both OpenSSL/mbedTLS and wolfSS
HEAD is now at d037ec8 Add note that uECC_VLI_NATIVE_LITTLE_ENDIAN affects key compatiblit
HEAD is now at fb49791 Update the esp32 bt lib (bfbbe1) 1.The updateed lib in the commit "66ecb769e" is still the old one. This commit is to update it. 2.The controller may miss the sleep time caculated before. So it will stuck in the loop to get the deep sleep HW flag. Then the watchdog issue happen
HEAD is now at 12f00c4 Update ESP32-C3 bt lib (9c99115) - Fixed update exception list assert - Fixed no adv report in sacn when using HW recorrect - support HW CCA - Fixed data length update rejected when controller is updating data lengt
Updating files: 100% (627/627), done
HEAD is now at aef55bbf Nimble: Fix crash when attempting to do deini
HEAD is now at 085ca40 Enable build for different c librarie
HEAD is now at eeecc49 Merge pull request #312 from Skinner927/patch-
HEAD is now at 98954eb Merge pull request #375 from mrdeep1/fix_coap_tick
HEAD is now at e6945e6 esp_wifi:fix airkiss and esptouch find channel crash issue(88c87473
HEAD is now at 4698b39 espefuse: Increase PWR_OFF_NUM parameter when programming efuse
Updating files: 100% (134/134), done
HEAD is now at 968b8cc4 Improved Win32 setup file name
HEAD is now at d273527 Merge pull request #505 from Alanscut/release-1.7.1
Updating files: 100% (563/563), done
HEAD is now at 4f5e89fa Don't ignore azure-pipelines.ym
Updating files: 100% (386/386), done
HEAD is now at 2195f741 dhcp: Fix client identifier to be added to relevant packet
Updating files: 100% (1009/1009), done
HEAD is now at 6465247f6 Updated minimum cmake requirement down to 2.8.1
HEAD is now at f10321a Merge branch 'bugfix/remove_unnecessary_parenteses' into 'master
Updating files: 100% (661/661), done
HEAD is now at 8f7b008b Update bash_completio
HEAD is now at dac1a65 Merge pull request #283 from protobuf-c/edmonds/changelog/1.3.
HEAD is now at f5e26c4 fixes #16
Updating files: 100% (995/995), done
HEAD is now at 334e95fa Remove unused submodule
HEAD is now at 7d2bf62 Merge pull request #363 from Deltrix/patch-
HEAD is now at 7e8e249 Merge pull request #707 from SwiftEngineering/issue_70
HEAD is now at bb672b0 Merge branch 'feature/make_support_for_v3.3.1' into 'master
2021-10-17 09:16:12.074 --------
2021-10-17 09:16:18.873 idf_tools.py exists in IDF directory
2021-10-17 09:16:18.873 Adding extra Python wheels location. Setting environment variable PIP_EXTRA_INDEX_URL=https://dl.espressif.com/pypi
2021-10-17 09:16:18.874 idf_tools.py command: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py" --idf-path E:\Users\10212\esp32\esp-idf\
2021-10-17 09:16:18.874 Selection of targets testing command: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py" install --targets=""
2021-10-17 09:16:21.740 Selection of targets: Not supported in this version idf_tools.py
2021-10-17 09:16:21.740 Installing tools:E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py" --idf-path E:\Users\10212\esp32\esp-idf\ install
2021-10-17 09:29:48.523 Done, exit code=1
2021-10-17 09:29:48.523 --------
2021-10-17 09:29:48.523 Running command: E:\Users\10212\esp32\.espressif\tools\idf-python\3.8.7\python.exe "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py" --idf-path E:\Users\10212\esp32\esp-idf\ install
Installing tools: xtensa-esp32-elf, xtensa-esp32s2-elf, xtensa-esp32s3-elf, riscv32-esp-elf, esp32ulp-elf, esp32s2ulp-elf, cmake, openocd-esp32, ninja, idf-exe, ccache, dfu-util
Installing xtensa-esp32-elf@esp-2021r1-8.4.0
Downloading xtensa-esp32-elf-gcc8_4_0-esp-2021r1-win64.zip to E:\Users\10212\esp32\.espressif\dist\xtensa-esp32-elf-gcc8_4_0-esp-2021r1-win64.zip.tmp
WARNING: Download failure [WinError 10060] 由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败。
WARNING: Failed to download https
/github.com/espressif/crosstool-NG/releases/download/esp-2021r1/xtensa-esp32-elf-gcc8_4_0-esp-2021r1-win64.zip to E:\Users\10212\esp32\.espressif\dist\xtensa-esp32-elf-gcc8_4_0-esp-2021r1-win64.zip.tmp
WARNING: Download failure <urlopen error [WinError 10060] 由于连接方在一段时间后没有正确答复或连接的主机没有反应,连接尝试失败。>
Done
Extracting E:\Users\10212\esp32\.espressif\dist\xtensa-esp32-elf-gcc8_4_0-esp-2021r1-win64.zip to E:\Users\10212\esp32\.espressif\tools\xtensa-esp32-elf\esp-2021r1-8.4.0
Installing xtensa-esp32s2-elf@esp-2021r1-8.4.0
Downloading xtensa-esp32s2-elf-gcc8_4_0-esp-2021r1-win64.zip to E:\Users\10212\esp32\.espressif\dist\xtensa-esp32s2-elf-gcc8_4_0-esp-2021r1-win64.zip.tmp
/github.com/espressif/crosstool-NG/releases/download/esp-2021r1/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r1-win64.zip to E:\Users\10212\esp32\.espressif\dist\xtensa-esp32s2-elf-gcc8_4_0-esp-2021r1-win64.zip.tmp
ERROR: Failed to download, and retry count has expired
File "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py", line 1675, in <module>
main(sys.argv[1:])
File "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py", line 1671, in main
action_func(args)
File "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py", line 1322, in action_install
tool_obj.download(tool_version)
File "E:\Users\10212\esp32\esp-idf\\tools\idf_tools.py", line 705, in download
raise DownloadError()
__main__.DownloadError
2021-10-17 09:29:48.525 --------
2021-10-17 09:29:48.525 Message box (OK):
Installation has failed with exit code 1
2021-10-17 09:31:40.706 User chose OK.
2021-10-17 09:31:40.736 Message box (Yes/No):
Installation log has been created, it may contain more information about the problem.
Display the installation log now?
2021-10-17 09:31:44.051 User chose Yes.
2021-10-17 09:31:44.176 CurStepChanged raised an exception.
SSSSJX
Re: idf安装错误????
Postby SSSSJX » Mon Oct 18, 2021 12:31 pm
下离线安装包可行,或者更新pip好像也行
zhn1021256354
Re: idf安装错误????
Postby zhn1021256354 » Wed Nov 24, 2021 2:02 pm
只能用离线包
Users browsing this forum: user123 and 65 guests
