官方写的是一个配网任务,我想把配网任务改成一个函数,结果发现配不了网。
void smartconfig_init_start(void * parm) 这是配网任务
void smartconfig_init_start()这是配网函数,里面的内容都没改。
在官网的WiFi/smart_config中把配网的任务改成一个函数,为什么配不了网??
Re: 在官网的WiFi/smart_config中把配网的任务改成一个函数,为什么配不了网??
代码贴全一点,你这样描述问题,爱莫能助!
/* Esptouch example
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_wifi.h"
#include "esp_wpa2.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "esp_smartconfig.h"
#include "freertos/queue.h"
#include "driver/gpio.h"
#include "driver/timer.h"
#include "esp_timer.h"
/* FreeRTOS event group to signal when we are connected & ready to make a request */
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event,
but we only care about one event - are we connected
to the AP with an IP? */
static const int CONNECTED_BIT = BIT0;
static const int ESPTOUCH_DONE_BIT = BIT1;
static const char *TAG = "smartconfig_example";
static void smartconfig_example_task(void);
typedef enum
Led_off = 0,
Config_led,
Connect_led,
mqtt_connet
}smartLedMode_t;
smartLedMode_t led_mode =Led_off;
#define led 19
#define ledon gpio_set_level(led, 0)
#define ledoff gpio_set_level(led, 1)
void led_Init(void);
void test_timer_periodic_cb(void *arg);
void led_Init(void)
gpio_reset_pin(led);
gpio_set_direction(led, GPIO_MODE_OUTPUT);
ledoff;
esp_timer_handle_t test_p_handle = 0;
esp_timer_handle_t motor_tim = 0;
//定义一个周期重复运行的定时器结构体
esp_timer_create_args_t test_periodic_arg = {
.callback =
&test_timer_periodic_cb, //设置回调函数
.arg = NULL, //不携带参数
.name = "TestPeriodicTimer" //定时器名字
uint8_t ledcnt =0;
uint8_t ledtrun =0;
ledcnt++;
if((led_mode ==Config_led)&&(ledcnt >1)) //0不成功
ledtrun =!ledtrun;
ledcnt = 0;
gpio_set_level(led, ledtrun);
static void event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
smartconfig_example_task();
// xTaskCreate(smartconfig_example_task, "smartconfig_example_task", 4096, NULL, 3, NULL);
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
esp_wifi_connect();
led_mode =Led_off;
ledoff;
xEventGroupClearBits(s_wifi_event_group, CONNECTED_BIT);
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
xEventGroupSetBits(s_wifi_event_group, CONNECTED_BIT);
} else if (event_base == SC_EVENT && event_id == SC_EVENT_SCAN_DONE) {
ESP_LOGI(TAG, "Scan done");
} else if (event_base == SC_EVENT && event_id == SC_EVENT_FOUND_CHANNEL) {
ESP_LOGI(TAG, "Found channel");
} else if (event_base == SC_EVENT && event_id == SC_EVENT_GOT_SSID_PSWD) {
ESP_LOGI(TAG, "Got SSID and password");
smartconfig_event_got_ssid_pswd_t *evt = (smartconfig_event_got_ssid_pswd_t *)event_data;
wifi_config_t wifi_config;
uint8_t ssid[33] = { 0 };
uint8_t password[65] = { 0 };
uint8_t rvd_data[33] = { 0 };
bzero(&wifi_config, sizeof(wifi_config_t));
memcpy(wifi_config.sta.ssid, evt->ssid, sizeof(wifi_config.sta.ssid));
memcpy(wifi_config.sta.password, evt->password, sizeof(wifi_config.sta.password));
wifi_config.sta.bssid_set = evt->bssid_set;
if (wifi_config.sta.bssid_set == true) {
memcpy(wifi_config.sta.bssid, evt->bssid, sizeof(wifi_config.sta.bssid));
memcpy(ssid, evt->ssid, sizeof(evt->ssid));
memcpy(password, evt->password, sizeof(evt->password));
ESP_LOGI(TAG, "SSID:%s", ssid);
ESP_LOGI(TAG, "PASSWORD:%s", password);
if (evt->type == SC_TYPE_ESPTOUCH_V2) {
ESP_ERROR_CHECK( esp_smartconfig_get_rvd_data(rvd_data, sizeof(rvd_data)) );
ESP_LOGI(TAG, "RVD_DATA:");
for (int i=0; i<33; i++) {
printf("%02x ", rvd_data);
printf("\n");
ESP_ERROR_CHECK( esp_wifi_disconnect() );
ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
esp_wifi_connect();
} else if (event_base == SC_EVENT && event_id == SC_EVENT_SEND_ACK_DONE) {
xEventGroupSetBits(s_wifi_event_group, ESPTOUCH_DONE_BIT);
static void initialise_wifi(void)
s_wifi_event_group = xEventGroupCreate();
esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
assert(sta_netif);
ESP_ERROR_CHECK( esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_event_handler_register(SC_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL) );
ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
led_mode =Config_led;
EventBits_t uxBits;
ESP_ERROR_CHECK( esp_smartconfig_set_type(SC_TYPE_ESPTOUCH) );
smartconfig_start_config_t cfg = SMARTCONFIG_START_CONFIG_DEFAULT();
ESP_ERROR_CHECK( esp_smartconfig_start(&cfg) );
while (1) {
uxBits = xEventGroupWaitBits(s_wifi_event_group, CONNECTED_BIT | ESPTOUCH_DONE_BIT, true, false, portMAX_DELAY);
if(uxBits & CONNECTED_BIT) {
ESP_LOGI(TAG, "WiFi Connected to ap");
if(uxBits & ESPTOUCH_DONE_BIT) {
led_mode =Connect_led;
ESP_LOGI(TAG, "smartconfig over");
esp_smartconfig_stop();
vTaskDelete(NULL);
void app_main(void)
led_Init();
esp_err_t time_err = esp_timer_create(&test_periodic_arg, &test_p_handle);
time_err = esp_timer_start_periodic(test_p_handle, 50* 1000);
ESP_ERROR_CHECK( nvs_flash_init() );
initialise_wifi();
#include <string.h>
#include <stdlib.h>
typedef enum
Led_off = 0,
Config_led,
Connect_led,
mqtt_connet
}smartLedMode_t;
#define led 19
void led_Init(void)
ledoff;
//定义一个周期重复运行的定时器结构体
.callback =
uint8_t ledcnt =0;
uint8_t ledtrun =0;
ledcnt++;
ledtrun =!ledtrun;
ledcnt = 0;
esp_wifi_connect();
led_mode =Led_off;
ledoff;
printf("\n");
esp_wifi_connect();
assert(sta_netif);
EventBits_t uxBits;
while (1) {
vTaskDelete(NULL);
void app_main(void)
led_Init();
initialise_wifi();
Users browsing this forum: No registered users and 112 guests
