Chip is ESP32-D0WD-V3 (revision 3)
idf-4.3
问题:其他任务全部屏蔽,只有一个CAN初始化操作,在执行到中断注册时导致程序崩掉。
代码:
int local_CAN_init(void)
//gpio_pad_select_gpioSelect pad as a gpio function from IOMUX
//Time quantum
double __tq;
ESP_LOGW(TAG, "go into local_CAN_init");
CAN_cfg.speed = CAN_SPEED_125KBPS;
CAN_cfg.tx_pin_id = 23;
CAN_cfg.rx_pin_id = 22;
//enable module
DPORT_SET_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
//configure TX pin
gpio_set_level(CAN_cfg.tx_pin_id, 1);
gpio_set_direction(CAN_cfg.tx_pin_id,GPIO_MODE_OUTPUT);
gpio_matrix_out(CAN_cfg.tx_pin_id,CAN_TX_IDX,0,0);
gpio_pad_select_gpio(CAN_cfg.tx_pin_id);
//configure RX pin
gpio_set_direction(CAN_cfg.rx_pin_id,GPIO_MODE_INPUT);
gpio_matrix_in(CAN_cfg.rx_pin_id,CAN_RX_IDX,0);
gpio_pad_select_gpio(CAN_cfg.rx_pin_id);
//set to PELICAN mode
MODULE_CAN->CDR.B.CAN_M=0x1;
//synchronization jump width is the same for all baud rates
MODULE_CAN->BTR0.B.SJW =0x1;
//TSEG2 is the same for all baud rates
MODULE_CAN->BTR1.B.TSEG2 =0x1;
//select time quantum and set TSEG1
switch(CAN_cfg.speed){
case CAN_SPEED_1000KBPS:
MODULE_CAN->BTR1.B.TSEG1 =0x4;
__tq = 0.125;
case CAN_SPEED_800KBPS:
MODULE_CAN->BTR1.B.TSEG1 =0x6;
__tq = 0.125;
default:
MODULE_CAN->BTR1.B.TSEG1 =0xc;
__tq = ((float)1000/CAN_cfg.speed) / 16;
//set baud rate prescaler
MODULE_CAN->BTR0.B.BRP=(uint8_t)round((((APB_CLK_FREQ * __tq) / 2) - 1)/1000000)-1;
/* Set sampling
* 1 -> triple; the bus is sampled three times; recommended for low/medium speed buses (class A and B) where filtering spikes on the bus line is beneficial
* 0 -> single; the bus is sampled once; recommended for high speed buses (SAE class C)*/
MODULE_CAN->BTR1.B.SAM =0x1;
//enable all interrupts
MODULE_CAN->IER.U = 0xff;
//no acceptance filtering, as we want to fetch all messages
MODULE_CAN->MBX_CTRL.ACC.CODE[0] = 0;
MODULE_CAN->MBX_CTRL.ACC.CODE[1] = 0;
MODULE_CAN->MBX_CTRL.ACC.CODE[2] = 0;
MODULE_CAN->MBX_CTRL.ACC.CODE[3] = 0;
MODULE_CAN->MBX_CTRL.ACC.MASK[0] = 0xff;
MODULE_CAN->MBX_CTRL.ACC.MASK[1] = 0xff;
MODULE_CAN->MBX_CTRL.ACC.MASK[2] = 0xff;
MODULE_CAN->MBX_CTRL.ACC.MASK[3] = 0xff;
//set to normal mode
MODULE_CAN->OCR.B.OCMODE=__CAN_OC_NOM;
//clear error counters
MODULE_CAN->TXERR.U = 0;
MODULE_CAN->RXERR.U = 0;
(void)MODULE_CAN->ECC;
//clear interrupt flags
(void)MODULE_CAN->IR.U;
ESP_LOGW(TAG, "go into esp_intr_alloc");
//install CAN ISR
esp_err_t err = esp_intr_alloc(ETS_CAN_INTR_SOURCE,0,CAN_isr,NULL,NULL);
ESP_LOGW(TAG, "Error (%s) local_CAN_init!", esp_err_to_name(err));
//Showtime. Release Reset Mode.
MODULE_CAN->MOD.B.RM = 0;
// printf("CAN_cfg.speed:%d\r\n",CAN_cfg.speed);
// printf("CAN_cfg.tx_pin_id:%d\r\n",CAN_cfg.tx_pin_id);
// printf("CAN_cfg.rx_pin_id:%d\r\n",CAN_cfg.rx_pin_id);
//xTaskCreate(can_rx_task, "can_rx_task", 2048 * 2, (void *)0, 4, NULL);
ESP_LOGW(TAG, "go out local_CAN_init");
return 0;
重启日志:
fe80:0000:0000:0000:3694:54ff:fef5:55d8, type: ESP_IP6_ADDR_IS_LINK_LOCAL[0m
every init -- end-----------
[0;33mW (3081) ESP_CAN: go into local_CAN_init[0m
[0;33mW (3081) ESP_CAN: go into esp_intr_alloc[0m
abort() was called at PC 0x40082b13 on core 1
Backtrace:0x40087ff7:0x3ffb0cc0 0x400887c9:0x3ffb0ce0 0x4008f5be:0x3ffb0d00 0x40082b13:0x3ffb0d70 0x40082c5d:0x3ffb0da0 0x4013d6aa:0x3ffb0dc0 0x40132b9d:0x3ffb0df0 0x400d7d3a:0x3ffb0e10 0x40082939:0x3ffb0e30 0x4000bfed:0x3ffc8a80 0x4008beea:0x3ffc8a90 0x400dc7e7:0x3ffc8ab0 0x400dc849:0x3ffc8af0 0x400d804e:0x3ffc8b20 0x400d734c:0x3ffc8b40 0x4008bc81:0x3ffc8b70
麻烦给看下,谢谢
can中断注册导致程序崩溃问题
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: No registered users and 57 guests
- All times are UTC
- Top
- Delete cookies
About Us
