今天遇到个问题,修改了一下文件,加了信号量。然后工作好像也没问题。但串口打印红色信息。不知道是啥?
Get mqtt password success!
Get reg success!
The semaphore was created successfully!
The semaphore can now be used.
is registered!
got ip: 192,168,0,106
Broker url: mqtt://150.158.77.97
MQTT_EVENT_CONNECTED
GetOverlappedResult failed (PermissionError(13, '???????????????', None, 5))
Waiting for the device to reconnect..
Waiting for the device to reconnect.............
Waiting for the device to reconnect.....................
打印了这么多。后来就这样 没打印了。
第二次 idf.py -p COM21 monitor 又没发现了
难道是monitor软件发出来的?
请教请教。是个什么情况。
Re: 今天遇到个问题,修改了一下文件,加了信号量。然后工作好像也没问题。但串口打印红色信息。不知道是啥?
Waiting for the device to reconnect.. 这句 log monitor 的打印,这个意识说明串口不稳定,我们无法发现串口,最简单的验证方法是插拔板子的USB线,至于另外的 GetOverlappedResult failed (PermissionError(13, '???????????????', None, 5)) 更像是程序的打印。
我也遇到了这个问题,有时候会出现,不知道什么原因导致的。楼主解决了嘛
这部分 log 的出处是在 tools/idf_monitor_base/serial_reader.py 里,代码:
以及 serial/serialwin32.py:
串口读取数据异常了,这个是 python serial 库里报出的 exception。这个应该只有在 windows 下才有此问题。
当前使用的是什么开发板?用的是什么 windows 版本?是否也有其他工具在操作串口?出现这个问题时,直接退出 idf.py monitor,然后用其他串口工具,是否还能打开?
try:
data = self.serial.read(self.serial.in_waiting or 1)
except (serial.serialutil.SerialException, IOError) as e:
data = b''
# self.serial.open() was successful before, therefore, this is an issue related to
# the disappearance of the device
red_print(e)
yellow_print('Waiting for the device to reconnect', newline='')
self.serial.close()
while self.alive: # so that exiting monitor works while waiting
try:
time.sleep(RECONNECT_DELAY)
self.serial.open()
break # device connected
except serial.serialutil.SerialException:
yellow_print('.', newline='')
sys.stderr.flush()
yellow_print('') # go to new line
def read(self, size=1):
Read size bytes from the serial port. If a timeout is set it may
return less characters as requested. With no timeout it will block
until the requested number of bytes is read.
if not self.is_open:
raise PortNotOpenError()
if size > 0:
win32.ResetEvent(self._overlapped_read.hEvent)
flags = win32.DWORD()
comstat = win32.COMSTAT()
if not win32.ClearCommError(self._port_handle, ctypes.byref(flags), ctypes.byref(comstat)):
raise SerialException("ClearCommError failed ({!r})".format(ctypes.WinError()))
n = min(comstat.cbInQue, size) if self.timeout == 0 else size
if n > 0:
buf = ctypes.create_string_buffer(n)
rc = win32.DWORD()
read_ok = win32.ReadFile(
self._port_handle,
buf,
n,
ctypes.byref(rc),
ctypes.byref(self._overlapped_read))
if not read_ok and win32.GetLastError() not in (win32.ERROR_SUCCESS, win32.ERROR_IO_PENDING):
raise SerialException("ReadFile failed ({!r})".format(ctypes.WinError()))
result_ok = win32.GetOverlappedResult(
self._port_handle,
ctypes.byref(self._overlapped_read),
ctypes.byref(rc),
True)
if not result_ok:
if win32.GetLastError() != win32.ERROR_OPERATION_ABORTED:
raise SerialException("GetOverlappedResult failed ({!r})".format(ctypes.WinError()))
read = buf.raw[:rc.value]
else:
read = bytes()
else:
read = bytes()
return bytes(read)
Users browsing this forum: Bing [Bot] and 117 guests
